DrDiettrich:
Right, you need 2 more wires for powering the remote device. Unless you spend another power supply for the remote station.
I could have a separate power supply on the distant end, but don't the grounds have to connect?
chucktodd:
...Those drivers/receivers were designed for RS422. You are going to have to slow down your SPI below 1mhz, and watch your capacitance and definitely install termination loads. Do you have a oscilloscope to look at the signals? I would not be surprised if you see some pretty dirty waveforms.
Speed is not an issue for me in this project. The purpose of the project is to use a bunch of switches and lamps/LEDs to send 'signals' between two rooms. I plan on later adding some LCD numbers or an array of LEDs. I suppose speed may be more important at that time.
By terminal loads, do you mean 100 Ohm resistors between A and B of the respective Driver and Receiver? But what do you mean by 'watching your capacitance'?
I don't have an oscilloscope. I wish I did...
BigBobby:
You could use the LTC6820 ... Although you don't need the isolation it provides, it does convert SPI into a high frequency differential signal that can be transmitted 100 meters on one pair in a CAT5e cable.
The problem I foresee is that I can only find the LTC6820 (on DigiKey) in surface mounted format. I generally use through-hole format and sockets, in order to avoid frying the IC white my under par soldering technique.
Also, in the diagram you included, it looks like you need an induction coil on each side of the transmission line (attached to IP and IM). I'm trying to make my way through the data sheet, but I find them so confusing.
Again, thank for your help.
Here is my schematic so far. As you can see, I did not include both differential pairs for each line.
