i am using arduino Uno , 150 rpm 12V motors, and 5 sensor array (Digital).
http://allsensor.in/ProductDetail.aspx?CID=idqYWeBfRKs=&SEOType=BSuwhmB9Ll4=&PID=Ns5bsH/O7s4=
I don't know how to use digital sensors for PID control. I have code for analog sensor
// VARIABLES VARIABLES VARIABLES VARIABLES VARIABLES VARIABLES VARIABL
const int RIGHT_MOTOR = 11;
const int LEFT_MOTOR = 10;
const int RIGHT_FORWARD = 2;
const int RIGHT_REVERSE = 3;
const int LEFT_FORWARD = 4;
const int LEFT_REVERSE = 5;
int right_speed = 0;
int left_speed = 0;
long sensors[] = {0, 0, 0, 0, 0};
long sensors_average = 0;
int sensors_sum = 0;
boolean sensors_flag = false;
int line_count = 0;
int position = 0;
int proportional = 0;
long integral = 0;
int derivative = 0;
int last_proportional = 0;
int control_value = 0;
int max_difference = 222;
float Kp = .111;
float Ki = 0;
float Kd = 1;
// SETUP FUNCTION SETUP FUNCTION SETUP FUNCTION SETUP FUNCTION SETUP F
// TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST
// Setup motor direction control pins
pinMode(RIGHT_FORWARD, OUTPUT);
pinMode(RIGHT_REVERSE, OUTPUT);
pinMode(LEFT_FORWARD, OUTPUT);
pinMode(LEFT_REVERSE, OUTPUT);
// Initialize both motors to forward
digitalWrite(RIGHT_FORWARD, HIGH);
digitalWrite(RIGHT_REVERSE, LOW);
digitalWrite(LEFT_FORWARD, HIGH);
digitalWrite(LEFT_REVERSE, LOW);
// LOOP FUNCTION LOOP FUNCTION LOOP FUNCTION LOOP FUNCTION LOOP FUNCTI
read_sensors();
get_average();
get_sum();
get_flags();
process_flags();
get_position();
get_proportional();
get_integral();
get_derivative();
get_control();
process_control();
set_motors(right_speed, left_speed);
// READ_SENSORS FUNCTION READ_SENSORS FUNCTION READ_SENSORS FUNCTION R
void read_sensors()
// Take a reading from each of the five line sensors
for (int i = 0; i < 5; i++)
sensors[i] = analogRead(i);
// Round readings less than two hundred fifty down to zero to filter
// out surface noise
if (sensors[i] < 250)
sensors[i] = 0;
// GET_AVERAGE FUNCTION GET_AVERAGE FUNCTION GET_AVERAGE FUNCTION GET_
void get_average()
// Zero the sensors_average variable
// Generate the weighted sensor average starting at sensor one to
// keep from doing a needless multiplicaiton by zero which will
// always discarded any value read by sensor zero
for (int i = 1; i < 5; i ++)
sensors_average += sensors[i] * i * 1000;
// GET_SUM FUNCTION GET_SUM FUNCTION GET_SUM FUNCTION GET_SUM FUNCTION
void get_sum()
// Zero the sensors_sum variable
sensors_sum = 0;
// Sum the total of all the sensor readings
sensors_sum += int(sensors[i]);
// GET_FLAGS FUNCTION GET_FLAGS FUNCTION GET_FLAGS FUNCTION GET_FLAGS
void get_flags()
// If a perpendicular line was read set the sensors_flag and
// increment the line count
if (sensors_sum > 4450)
sensors_flag = true;
line_count++;
// PROCESS_FLAGS PROCESS_FLAGS PROCESS_FLAGS PROCESS_FLAGS PROCESS_FLA
void process_flags()
if (sensors_flag == true && line_count == 2)
// Make a right turn and acquire the center of the line
right_turn();
else if (sensors_flag == true && line_count == 3)
// Add code here
else if (sensors_flag == true && line_count == 4)
// Add code here
// Clear sensors_flag
// GET_POSITION FUNCTION GET_POSITION FUNCTION GET_POSITION FUNCTION G
void get_position()
// Calculate the current position on the line
position = int(sensors_average / sensors_sum);
// GET_PROPORTIONAL FUNCTION GET_PROPORTIONAL FUNCTION GET_PROPORTIONA
void get_proportional()
// Caculate the proportional value
proportional = position - 2000;
// GET_INTEGRAL FUNCTION GET_INTEGRAL FUNCTION GET_INTEGRAL FUNCTION G
void get_integral()
// Calculate the integral value
integral = integral + proportional;
// GET_DERIVATIVE FUNCTION GET_DERIVATIVE FUNCTION GET_DERIVATIVE FUNC
void get_derivative()
// Calculate the derivative value
derivative = proportional - last_proportional;
// Store proportional value in last_proportional for the derivative
// calculation on next loop
last_proportional = proportional;
// GET_CONTROL FUNCTION GET_CONTROL FUNCTION GET_CONTROL FUNCTION GET_
void get_control()
// Calculate the control value
control_value = int(proportional * Kp +
integral * Ki +
derivative * Kd);
// PROCESS_CONTROL PROCESS_CONTROL PROCESS_CONTROL PROCESS_CONTROL PRO
void process_control()
// If the control value is greater than the allowed maximum set it
// to the maximum
if (control_value > max_difference)
control_value = max_difference;
// If the control value is less than the allowed minimum set it to
// the minimum
if (control_value < -max_difference)
control_value = -max_difference;
// If control_value is less than zero calculate a right turn to
// acquire the center of the line
if (control_value < 0)
right_speed = max_difference + control_value;
left_speed = max_difference;
// If control_value is greater than zero calculate a left turn to
right_speed = max_difference;
left_speed = max_difference - control_value;
// SET_MOTORS FUNCTION SET_MOTORS FUNCTION SET_MOTORS FUNCTION SET_MOT
void set_motors(int right_speed, int left_speed)
// Adjust the motor speeds according to the calculated values
analogWrite(RIGHT_MOTOR, right_speed);
analogWrite(LEFT_MOTOR, left_speed);
// RIGHT_TURN FUNCTION RIGHT_TURN FUNCTION RIGHT_TURN FUNCTION RIGHT_T
void right_turn()
// Cut power from left and right motors and coast until
// perpendicular line is passed
set_motors(0, 0);
delay(250);
// Take new sensor zero reading
sensors[0] = analogRead(0);
// Initialize the right motor for reverse travel
digitalWrite(RIGHT_FORWARD, LOW);
digitalWrite(RIGHT_REVERSE, HIGH);
// Turn right until the edge of the line is acquired
while (sensors[0] < 500)
set_motors(222, 222);
// Initialize the right motor back to forward travel
I don't know where to modify the code.
Plz help!!!
