Hi !
I followed these instructions to use compiler optimization flags when compiling from the Arduino IDE.
When I set the optimization level to fast (using the argument -Ofast), I get the following error when compliling my code, which is using the following Library:
In function `global constructors keyed to 65535_0_Device.cpp.o.6022':
<artificial>:(.text.startup+0x7d4): undefined reference to `Adafruit_CharacterOLED::command(unsigned char)'
Does anybody understand why this happens and how to fix it?
kind regards,
Flub
I found a line of code which i can comment out to make the error disappear. Perhaps someone can understand why this line is a problem:
The problem occurs when using the LCD::command method from inside the class method first time.
When i uncomment the line where it is used, the compiling works. I think it is because command method of the LCD (or Adafruit_CharacterOLED) is inlined only when using optimization flags other than -Os. So inline is ignored when using -Os and starts to do something when I use -Ofast.
So why could the inline of the LCD::command Method be a problem here:
I created an example sketch which reproduces the error:
(Note: I renamed the library from Adafruit_CharacterOLED to LCD)
#include "LCD.h"
LCD lcd(OLED_V2, A13, A12, A14, A8, A9, A10, A11);
lcd.print("test");
lcd.command(LCD_FUNCTIONSET | LCD_EUROPEAN_I);
Edit: I just found this post on the forums here:
But i think removing the inline directive in the Library is somehow not a solution as it just disables the intended optimization.
I now just edited the Libray, i renamed the command function to _command and put it in the private scope. Then I added a non inlined function in the public space called command which just calls the _command function. I am not sure but perhaps the positive effect of inlining is kept like this. and a call to command from outside is happening only once when choosing the characterset anyways...
