Linking arduinos through RF
Greets everybody this is my first post on the forum and first project with the arduino. In the end I'm looking to create a simple txt messaging network with 2-5 (phones) but so far I am unable to do even the simplest communication.
Hardware:
RF Link 4800bps Receiver - 315MHz
RF Link Transmitter - 315MHz
Transmitter Code:
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
int val = 0;            // variable to store the value
SoftwareSerial rfSerial = SoftwareSerial(rxPin, txPin);   //using softwareserial
 rfSerial.begin(9600);       //initialize softwareserial
 Serial.begin(9600);         // begin serial communication over USB to the computer for debugging purposes
void loop(){
     val = 1020;
     Serial.print(val);               // send data to computer
     rfSerial.print(val, DEC);    // send data out tx
     //PreVal = val;
     delay(100);
Receiver Code:
#define rxPin 2
#define txPin 3
int val = 0;
 pinMode(rxPin, INPUT);              // set up pin for serial comm. with RF receiver
 rfSerial.begin(9600);                 // begin serial connection with RF Link unit
void loop(){
               val = rfSerial.read();           //Read a Byte?? from the RX
               if ( val == 1020 ) {
               Serial.print(val, DEC);         // send data to computer in Decimal
If it's a 4800bps RF link, why are you running it at 9600?
You're sending the value as an ASCII decimal string - that's how you should receive it too.
Thank you for the fast reply, I have changed the rates to 4800 on both transmitter and receiver code not sure how I overlooked that.
how would I go about doing this?
once again thank you for the support I hope to contribute as soon as I learn my way around the arduino.
OK, you're transmitting the characters '1' '0' '2' '0'.
In hex, these characters are represented by the byte values 0x31, 0x30, 0x32, 0x30.
So four bytes.
You need to collect all four characters, and then convert the collection to decimal.
Search for "atoi".
You'll need to convert the four characters to a string first.
hi,
i trying the exact same thing :slight_smile:
but just want to send one byte(0 or 1) from one board to another also using seperate transmitter/receiver modules...it should act like an on/off switch, found any solution yet?????
my boards operate with 868 mhz do u know how to find out the baud rate? here is the link to my boards:
http://www2.produktinfo.conrad.com/datenblaetter/175000-199999/190939-an-01-ml-Sende_Empfaenger_ModulSet_868MHz_de-en.pdf
thx
akira
Well, my German's not great (all but non-existant), but "Bandbreite" has to translate as "Bandwidth" (Band-breadth, literally, I guess), so at 2kHz, I wouldn't expect to be able to push the bit-rate much past 1200 bps.
hi,
thx for the answer, but even with the changed baud rate i'm only getting
a zero as an output on both the receiver and transmitter even by putting them on one board??????? maybe there is a prob with the type of value i'm transmitting(byte, dec, int)....i'm getting nuts already!!!!!
thx
akira
#define rxPin 2
#define txPin 3
int val = 0;            // variable to store the value coming from the sensor
 pinMode(rxPin, INPUT);      //set recieve as an input
 pinMode(txPin, OUTPUT);     //set transmit as an output
 rfSerial.begin(1200);       //initialize softwareserial
void loop(){
     val = 1;
     Serial.println(val, DEC);     // send data to computer
     rfSerial.print(val);    // send data out tx
     Serial.print("reader: ");
     delay(100);
Aren't these
synchronous?
If they are, then I wouldn't expect to receive anything.
hi,
i thought the print command always goes to the tx and the read checks the rx or am i mistaking something???
Yes, but if you take a look at the software serial library, you'll see that everything takes place syncrhonously.
First, the "rfSerial.print ()" clocks out to the Tx pin all the data it has been given, then the "rfSerial.read()" looks for a start bit on the Rx.
But the start bit has already disappeared into the ether, via the Tx pin, as has all the data and the stop bit.
okay, so what would be the solution, a delay perhaps or would it work by just sticking it on two boards one for the receiver and one for the transmitter?
thx again and many more times :slight_smile:
A delay can't work, so yes, try putting tx and rx on different boards.
been there done that...here is my code 4 the two boards...still getting random values(mostly 0) on the receiver side
transmitter code:
#define rxPin 2
#define txPin 3
 pinMode(rxPin, INPUT);//set recieve as an input
 pinMode(txPin, OUTPUT);//set transmit as an output
void loop(){
     //val = analogRead(potPin);    // read the value from the sensor
     val = 1;
     delay(100);
receiver code:
#define rxPin 2
#define txPin 3
int val = 0;
 rfSerial.begin(1200);                 // begin serial connection with RF Link unit
void loop(){
               delay(100);
WHY WON'T IT WORK!!!!!!!
thx for ur time
funny thing is when i comment out the delay on the receiver side i get values up th a**???
What are the other values?
I don't understand this sentence.
The delay on the receiver should be much less than the delay on the transmitter.
I'd be inclined to drop the bit-rate as low as possible, say 300bps
These lines are irrelevant.
these are the values i get with 300bps and 100ms delay at the receiver:
0000003200000000000000320000000800000000000001200000000000000004000000020000000000000012800000400000000000000000000000000000000000000000000000000000000004810000000000024012800081665000000006400000000960000064000000000000001280-1000000000000004800000
and these i get with 300 baud and no delay at the receiver:
10000004096406408648140480016016080009900286580324032480032130289713403312800192000166500006443238644000161032138489740328008974060003266001281600448132800410161290003200320160432006403341620644-1000028448006412000012880016130032048650330326480016194281136169700088
Can you write a simple Rx sketch to simply copy the state of the rx pin to a LED?
Just a simple "loop()" with a "digitalWrite (ledPin, digitalread (rxPin));"
Now turn off the Tx completely - what do you see?
I used to have a similar problem, eventually traced to a wireless door bell...
hi,
here is the code
#define rxPin 2
#define txPin 3
int ledPin = 13;
int val = 0;
 //pinMode(rxPin, INPUT);                // set up pin for serial comm. with RF receiver
 //pinMode(txPin, OUTPUT);               //set transmit as an output
 rfSerial.begin(300);                 // begin serial connection with RF Link unit
void loop(){
 val = digitalRead(rxPin);
  digitalWrite (ledPin, val);
               //val = rfSerial.read();           //Read a Byte?? from the RX
               delay(100);
i disconnected the transmitter board from the usb so there should be nothing coming in, however the led flashes now and then at a seemingly constant rate
here is the output of the output window:
00000000000000001100011000110001100011000110001100011000110001100011000110001100011000110001100011000110001100011000110001
What if you enable Rx pullup?
whats Pullup???
