I am using the following camera: https://cdn.sparkfun.com/datasheets/Sensors/LightImaging/JPEG%20camera%202M%20UM.pdf
with an arduino due and a SD card shield. My aim is to get the camera to take a picture and to save it on the SD card and also see the "output" on the Serial Monitor. I am having a bit of trouble, and i'm not sure where i am going wrong, at the moment it has no errors, but there are only blank jpeg files on the SD card. It says that they don't contain anything. Could anyone point me to the section of code which needs work on, i'm assuming it is either the commands (which i have checked against the data sheet) or the transfer of bytes.
I have now gone to this site and basically copied in this tutorial to try and get it to work.
I have changed a few things, taken out soft serial and used the hard serial on my DUE. Added in SPI.h as i am using a SD shield.
Here is the code:
#include <SD.h>
#include <SPI.h>
byte ZERO = 0x00;
byte incomingbyte;
long int a=0x0000,j=0,k=0,count=0,i=0;
uint8_t MH,ML;
boolean EndFlag=0;
File myFile;
void SendResetCmd();
void SetBaudRateCmd();
void SetImageSizeCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
Serial.begin(38400);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial1.begin(38400);
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
byte a[32];
int ii;
SendResetCmd();
delay(4000); //Wait 2-3 second to send take picture command
SendTakePhotoCmd();
while(Serial1.available()>0)
incomingbyte=Serial1.read();
myFile = SD.open("pic.jpg", FILE_WRITE); //<strong><span style="color: #ff0000;">The file name should not be too long</span></strong>
while(!EndFlag)
j=0;
k=0;
count=0;
SendReadDataCmd();
delay(20); //250 for regular
k++;
if((k>5)&&(j<32)&&(!EndFlag))
a[j]=incomingbyte;
if((a[j-1]==0xFF)&&(a[j]==0xD9)) //tell if the picture is finished
EndFlag=1;
j++;
count++;
for(j=0;j<count;j++)
if(a[j]<0x10)
Serial.print("0");
Serial.print(a[j],HEX); // observe the image through serial port
Serial.print(" ");
for(ii=0; ii<count; ii++)
myFile.write(a[ii]);
i++;
myFile.close();
Serial.print("Finished writing data to file");
while(1);
void SendResetCmd()
Serial1.write(0x56);
Serial1.write(ZERO);
Serial1.write(0x26);
Serial1.write(0x31);
Serial1.write(0x05);
Serial1.write(0x04);
Serial1.write(0x01);
Serial1.write(0x19);
Serial1.write(0x11);
Serial1.write(0x24);
Serial1.write(0x03);
Serial1.write(0x2A);
Serial1.write(0xC8);
Serial1.write(0x36);
MH=a/0x100;
ML=a%0x100;
Serial1.write(0x32);
Serial1.write(0x0c);
Serial1.write(0x0a);
Serial1.write(MH);
Serial1.write(ML);
Serial1.write(0x20);
a+=0x20;
Thank you for your pointers. Some of them i can't answer, i took this from a tutorial on the manufactures website, so i assumed it would work. The baud rate should be 115200, i thought that is set up later through the SetBaudRateCMD, will look into it. Not sure why there is a global.
Will have a look at the two serial.read commands and come back with an answer....
I have changed the serial baud rate to 9600 and the camera serial to 115200 as in the instruction manual for it. I have also added a delay before the while(Serial1.available()>0) command.
I now have HEX on my serial monitor (see next post).
PaulS:
byte incomingbyte;
Why is this global?
Would this make a difference if it is global or local?
PaulS:
k++;
a[j]=incomingbyte;
EndFlag=1;
j++;
count++;
Some
piss-poorly
indented
code
that
reads
data
and
effectively
discards
it.
Why?
Once the array is full, you should deal with the data in the array.
Would this need another delay before it? I'm not too sure what needs altering here?
#include <SD.h>
#include <SPI.h>
byte ZERO = 0x00;
byte incomingbyte;
uint8_t MH,ML;
boolean EndFlag=0;
File myFile;
while (!Serial) {
Serial1.begin(115200);
if (!SD.begin(4)) {
return;
byte a[32];
int ii;
SendResetCmd();
SendTakePhotoCmd();
delay(100);
while(!EndFlag)
j=0;
k=0;
count=0;
SendReadDataCmd();
k++;
a[j]=incomingbyte;
EndFlag=1;
j++;
count++;
if(a[j]<0x10)
Serial.print("0");
Serial.print(" ");
i++;
myFile.close();
while(1);
void SendResetCmd()
MH=a/0x100;
ML=a%0x100;
Serial1.write(MH);
Serial1.write(ML);
a+=0x20;
