LiquidCrystal begin() errors when outside of setup()
Using the IDE on OSX, the following code :
#include <LiquidCrystal.h>
// initialize the display
const int rs = 7, en = 8, d4 = 9, d5 = 10, d6 = 11, d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// Setup LCD
lcd.begin(16, 2);
Produces an error
references:8:1: error: 'lcd' does not name a type
 lcd.begin(16, 2);
exit status 1
I am just interested in why the lcd.begin() call must be within setup() function in order to compile without errors.
Because it’s a function call.
Function calls must go inside a { } code block (which must be inside/part of a function).
If it's outside a function it must be a declaration. If it's a declaration it must start with a data type. The identifier 'lcd' is the name of an object instance and "does not name a type".
Thank you so much - Been many years since I played with C - I've been corrupted by too many years working in Perl, PHP and python. Will try not to ask such a noob question again!
