Hello!
newbie here, is the output of this sensor digital or analog? Has anyone here used this sensor for a tachometer project and can tell me what the maximum detection frequency is? some datasheets say 100hz others say 500hz for the same model. I would like to use it to measure speeds from 150-3000 rpm. Any help is appreciated and thank you all in advance!
have a look at linterfacing-inductive-proximity-sensor-lj12a3-4-z-bx-with-arduino
have you considered using a QEI encoder?
thank you very much, have you got an idea about the frequency response? an qei encoder is a good idea although i think it's not suited for the project i'm doing ( car engine rpm counter) thanks again.
