Load Cell- SD card project connection failure
Hello, I have a project which measure weight and store it to SD card. Both sensor work efficiently load cell and SD card but the problem is that I cannot combine their code each self. How can fixed the code to store the data in SD card and display in serial monitor ?
I wire jumpers Arduino UNO to SD Card module like below:
GND => GND // GCC => 5V // MISO => 12 // MOSI => 11 // SCK => 13 // CS => 10
  SD card datalogger
  This example shows how to log data from three analog sensors
  to an SD card using the SD library.
  The circuit:
   analog sensors on analog ins 0, 1, and 2
   SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
  created  24 Nov 2010
  modified 9 Apr 2012
  by Tom Igoe
  This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 6; //mcu > HX711 dout pin
const int HX711_sck = 7; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
const int chipSelect = 4;
File dataFile;
  Serial.begin(57600);
  Serial.println("Starting...");
  Serial.println("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  LoadCell.begin();
  //LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
  unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  LoadCell.start(stabilizingtime, _tare);
  if (LoadCell.getTareTimeoutFlag() || LoadCell.getSignalTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
    while (1);
  else {
    LoadCell.setCalFactor(1.0); // user set calibration value (float), initial value 1.0 may be used for this sketch
    Serial.println("Startup is complete");
  while (!LoadCell.update());
  calibrate(); //start calibration procedure
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check for new data/start next conversion:
  if (LoadCell.update()) newDataReady = true;
  if(datafile)
    dataFile = SD.open("datalog.txt", FILE_WRITE);
  // get smoothed value from the dataset:
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
      float i = LoadCell.getData();
      dataFile.println(i);
      dataFile.close();
      Serial.print("Load_cell output val: ");
      Serial.println(i);
      newDataReady = 0;
      t = millis();
  else {
    Serial.println("error opening datalog.txt");
  // receive command from serial terminal
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if (inByte == 't') LoadCell.tareNoDelay(); //tare
    else if (inByte == 'r') calibrate(); //calibrate
    else if (inByte == 'c') changeSavedCalFactor(); //edit calibration value manually
  // check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
void calibrate() {
  Serial.println("***");
  Serial.println("Start calibration:");
  Serial.println("Place the load cell an a level stable surface.");
  Serial.println("Remove any load applied to the load cell.");
  Serial.println("Send 't' from serial monitor to set the tare offset.");
  boolean _resume = false;
  while (_resume == false) {
    LoadCell.update();
      _resume = true;
  Serial.println("Now, place your known mass on the loadcell.");
  Serial.println("Then send the weight of this mass (i.e. 100.0) from serial monitor.");
  float known_mass = 0;
  _resume = false;
    LoadCell.update();
      known_mass = Serial.parseFloat();
      if (known_mass != 0) {
        Serial.print("Known mass is: ");
        Serial.println(known_mass);
        _resume = true;
  LoadCell.refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
  float newCalibrationValue = LoadCell.getNewCalibration(known_mass); //get the new calibration value
  Serial.print("New calibration value has been set to: ");
  Serial.print(newCalibrationValue);
  Serial.println(", use this as calibration value (calFactor) in your project sketch.");
  Serial.print("Save this value to EEPROM adress ");
  Serial.print(calVal_eepromAdress);
  Serial.println("? y/n");
  _resume = false;
      if (inByte == 'y') {
        EEPROM.begin(512);
#endif
        EEPROM.put(calVal_eepromAdress, newCalibrationValue);
        EEPROM.commit();
#endif
        EEPROM.get(calVal_eepromAdress, newCalibrationValue);
        Serial.print("Value ");
        Serial.print(" saved to EEPROM address: ");
        Serial.println(calVal_eepromAdress);
        _resume = true;
      else if (inByte == 'n') {
        Serial.println("Value not saved to EEPROM");
        _resume = true;
  Serial.println("End calibration");
  Serial.println("To re-calibrate, send 'r' from serial monitor.");
  Serial.println("For manual edit of the calibration value, send 'c' from serial monitor.");
void changeSavedCalFactor() {
  float oldCalibrationValue = LoadCell.getCalFactor();
  Serial.print("Current value is: ");
  Serial.println(oldCalibrationValue);
  Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
  float newCalibrationValue;
      newCalibrationValue = Serial.parseFloat();
      if (newCalibrationValue != 0) {
        Serial.print("New calibration value is: ");
        Serial.println(newCalibrationValue);
        LoadCell.setCalFactor(newCalibrationValue);
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
  Serial.println("End change calibration value");
I'd ditch your current code and go through this, step by step, including re-wiring your setup to match their pins. If this works, then you have a good place to start integrating the HX711.
I'm so sorry for my late response. I edit the code and There is only one problem that I cannot write data on SD card. İn loop section there is a displaying load cell data code. I use it also to write on the SD card but when I run the code just only displaying serial.print sentences not the current load cell data and also it did not create a file to save data. I will provide the code which I edit.
  SD card datalogger
  The circuit:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
  created  24 Nov 2010
  modified 9 Apr 2012
  by Tom Igoe
#include <SPI.h>
#include <SD.h>
#include <EEPROM.h>
#endif
//pins:
File dataFile;
    while (1);
  LoadCell.begin();
    while (1);
  else {
  while (!Serial) {
  if(datafile)
  if (newDataReady) {
      dataFile.close();
      Serial.println(i);
      newDataReady = 0;
      t = millis();
  else {
void calibrate() {
    LoadCell.update();
      _resume = true;
  _resume = false;
    LoadCell.update();
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
Did you format your card in accordance with the tutorial in post #2?
Did you successfully run the cardinfo example mentioned in the tutorial in post #2?
Did you successfully run the readwrite example mentioned in the tutorial in post #2?
You should do all three before adding in any HX711 code.
Yes I successfully run example codes. But in my complex code (loadcell-sd card) there is a wrong process opening and closing file. There are some if-else statement. When I carry the SD card code into Load cell's if statement and run the code, then the output is include only printf term. So I have been too confused since I started this project. I tried many probability but none of them turned out the way I wanted.
So unless someone steps up to debug it for you, I'd suggest starting over. Begin with an example that works and gradually add features, testing every new addition. Don't try to build the Taj Mahal in one go.
