Local->Global
As the title says, is there a way for making a local object into a Global?
I have some projects with a WiFiManager. Its example works like a charm. However, there is a function:
wifiManager.resetSettings();
that I want to call from a loop by a key. Problem is that wifiManager is declared inside the setup.
An example is AutoConnectWithFSPParameters.
Or, is there another way? I am all ears.
Post an example sketch showing the problem
Why ?
UKHeliBob:
Why ?
Compiling.
exit status 1
'wifiManager' was not declared in this scope
Just use AutoConnectWithFSPParameters.ino and put anywhere inside Loop this:
You don't have to upload it, obviously. Just try to compile.
I can upload this example, but just to waste space here.
Not why is it a problem, rather why declare it in setup() when you want to use it elsewhere ?
