Logical error when using a lib
Hey,
I'm using a slightly modified Version of the DCF77 Lib.
When i use it like that:
DCF77 DCF( Pin );
Void setup()
Void loop()
The code is compiled correctly but get's stuck somewhere in runtime. I don't know where, because serial.print doesn't work also. So it must hung up some where in the constructor. But the constructor just set's up some variables.
But when i use it like that:
Void setup()
    DCF77 DCF( Pin );
Void loop()
the code runs exactly as expected. BUT: the Lib is just local in setup and not usable in the project.
How can this be possible and how can I fix it?
Thanks and regards.
please post the whole code and a link to the DCF library used (or its code as a zip attachment) so we can replicate.
here it is.
thanks and regards
code.zip (6.74 KB)
Nobody an idea?
Thanks regards
