Okay, the 2560 is running this:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0x6E, 0xEF, 0xFA, 0xED };
IPAddress ip(192, 168, 1, 157);
unsigned int localPort = 8888; // local port to listen on
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
// start the Ethernet and UDP:
Ethernet.begin(mac,ip);
Udp.begin(localPort);
int packetSize = Udp.parsePacket();
if(packetSize)
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i =0; i < 4; i++)
Serial.print(remote[i], DEC);
if (i < 3)
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
Serial.println("Contents:");
Serial.println(packetBuffer);
// Ok, this is just tacked on straight from the ethernet reference.
// TX RX flash like mad but neither board gives anything from serial mon.
// If I understand correctly, this will just repeatedly broadcast 'hello'
// Which should be received by the other board which will then reply with
// The canned 'acknowledged' from the UDPSendReceiveString example code.
// But obviously I'm wrong because my code doesn't work. :)
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write("hello");
Udp.endPacket();
delay(13);
Which is obviously just two bits of code stolen right from the ethernet library reference.
The Uno is running this code:
#include <SPI.h> // needed for Arduino versions later than 0018
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xAE, 0xED };
IPAddress ip(192, 168, 1, 107);
// buffers for receiving and sending data
char ReplyBuffer[] = "acknowledged"; // a string to send back
EthernetUDP Udp;
// if there's data available, read a packet
if(packetSize)
if (i < 3)
Serial.print(".");
// send a reply, to the IP address and port that sent us the packet we received
Udp.write(ReplyBuffer);
Udp.endPacket();
Udp.endPacket();
delay(17);
Which is just the UDPSendReceive example from the IDE.
I (wrongly) assumed that if I just broadcasted a packet, the other one would pick it up and reply with its own. But, both serial monitors are blank.
I hope my total lack of understanding of the Ethernet/UDP library isn't showing too badly.
