Hi guys,
Im trying to get a transistor to work as a switch. I understand that you have to use resistors with these sorts of things, but when I looked up calcualtors to do the equations I found them rather intimidating and confusing. So I've come here for help
This is a rough sketch of my circuit
Im not sure if I'm supposed to be doing this (although it looks a lot clearer too me now that i'm seeing it on paper), but is it possible to siphon off a battery like that to be used in its full voltage state while still using a voltage converter?
Anyway, you probably need to know the specs in order to help me so here goes
DC current gain - 200
Base emitter saturation voltage - 0.9V
Current going into the collector - 9V
Current going into the base - 5V
Resistance between collector and emitter - 650 ohms
Desired amp on emitter - regular 9V battery amperage based on the above resistance
And here's the datasheet in case i'v missed anything
So I would like to know what value resistors I should use and where I should put them.
Thanks,
FactualOrc.
