Hi all.
Are there any suggestions for ESP32S3 clock without use of internet?
Thanks
Adam
What are the requirements?
Thanks.
Just want to make a watch, no much requirements...
RTC module is your best bet unless your final thingy is limited in size
Thanks.
you are right, the RTC module, but during my testing I got difficult of USB communication, and some one mentioned that the confliction between RTC module (pin49?) and USB.
size is also a matter.
I mean as long as it can work as clock. no much precision etc.
Hello shanren
Take a search engine of your choice and ask the WWW for 'time trigger +arduino' to gain the knowledge.
Thanks.
Is it OK to use ESP32 intern RTC works as a clock? any example here?
Hello shanren
Take a search engine of your choice and ask the WWW for 'ESP32 intern RTC ' to gain the knowledge.
The ESP32 isn't accurate like DS3231. Why use a RTC if you use an ESP32. Why not NTP? DS3231 has nothing to do with USB. It use I2C.
Thank you.
trying to make a watch without Internet.
fount one like this:
not sure if it's OK to be as a watch.
Why so? An RTC purpose is to keep and provide time on demand. A watch displays time. So what is your difficulty?
Also why the ESP32S3 specifically?
Why do you need a USB for standalone watch?
Thanks.
Firstly I used external DS3231 because of the accurate, and got difficulty to serial monitor; the ESP32S3 specifically is it doesn't have default I2C, at least I didn't find.
Thanks.
For debug purpose.
Perhaps because most ESP32 can direct the I2C port to almost any pins. You just pass the pin numbers to the Wire object constructor.
Thanks.
how to set the clock current time?
You have to dig into the ESP32 time library documentation at the Espressif site. I suppose there are not examples because 99.999% of ESP32 systems that use the clock, also set it by NTP.
Thank you!
how to let the ESP32'S OLED shown like hour, minute and to type in the current time?
