Looking for continuous rotary component with strong detents
I'm working on a project where I need a component for selecting values/positions. Normally I'd just go with a rotary encoder, but I'm not happy with the feel of them. I'm building an audio controller with a retro look, so I'd love to have more "rustic" controls that match the aesthetic. On top of that, I need up to 48 positions total.
My idea to handle the 48 positions would be to use 12 positions per revolution (1st turn: 0–11, 2nd turn: 12–23, and so on).
So my question is: Is there a component that has strong, satisfying detents, 12 positions per revolution (could be 8 or 10 as well), AND can rotate continuously without a hard stop?
Rotary switches would be perfect feel-wise since they have that nice detented action, but of course they're not continuous.
Any ideas?
They are if you remove the stop that prevents continuous rotation
Oh great, thanks! I'll give it a try.
Is this something that's actually designed to be done, or would I have to break/modify something to make it work?
You would need to modify the switch and this may not be possible on all of them
I suggest that you buy a couple of different ones and give it a try
There are many such rotary encoders that output a binary value. Such as 0-f in 4 bits on 4 pins plus the common or ground pin.
From long ago, there is a lock pin that determines the number of positions that you can set. If you have e.g. a rotary switch with 6 positions and you only need 4 you can move the lock pin so you will only have 4 "clicks". Tried to find a picture for it but failed. I however found https://docs.rs-online.com/308d/0900766b81465d93.pdf
It sounds like the problem is not with finding 12 position rotary encoder, rather that @ianm2 wants one with strong detents
What's the budget? I'd like to play with these
There are some DIY projects on this, too. Nothing I would ever be able to do…
a7
The strongest detents I have seen is where you pull the knob on the switch so the pin clears the hole, rotate the knob/switch and let the spring pull the pin into the new hole. I think it was military radio equipment.
Compare the "Detent Torque" in various encoder datasheets.
tork
em14-2.pdf (786.3 KB)
https://www.amazon.com/uxcell-Positions-Knurled-Diameter-Selector/dp/B07CG9RPKY/ref=asc_df_B07CG9RPKY?tag=bngsmtphsnus-20&linkCode=df0&hvadid=80333278395851&hvnetw=s&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=96675&hvtargid=pla-4583932755377224&psc=1&msclkid=a0ef14372db71b6324107da86e64993c
You'd surely get better quality at DigiKey or Mouser but this could get you started.
Read the positions with an analog (or two) channel or feed the inputs to a (cascaded) PISO shift register.
Going from position twelve to position thirteen would have to be monitored with software.
I found a miniature 12 position rotary switch, single circuit, $56.00.
652-PEC11H4120FS0020
at
https://www.mouser.co.uk/ProductDetail/Bourns/PEC11H-4120F-S0020?qs=7MVldsJ5Uaxh8cksqYCfvg%3D%3D&mgh=1&vip=1&utm_id=20797887765&utm_source=google&utm_medium=cpc&utm_marketing_tactic=emeacorp&gad_source=1&gad_campaignid=20808116062&gbraid=0AAAAADn_wf12LT7we0pr4g41g3dYcEK1H&gclid=CjwKCAiAnoXNBhAZEiwAnItcG_byffBbYNw3Lf9GPTEQkwzPe0_dQ9Sq8Vu4lNjCMrm5TmksOZ42qBoCSwcQAvD_BwE
had what seemed a relatively heavy detent of the few I found.
Detent 210 ± 70 gf—cm (2.0 ± 0.1 oz-in)
Pricing (VAT Inclusive) | Qty. 1 | £2.74
EDIT:
On a project for which I wanted to select 24 options I opted for an at hand 1P x 12W rotary swich and a two way toggle.
Attributed to Ben Franklin:
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
:slightly_smiling_face:
