I don't see why interrupts never seem to start. no millis.
// EBRC temperature sensor application 11/2015 tmw
int sensorTemp1Pin = A0; // select the input pin for temp1
int sensorTemp2Pin = A1; // select the input pin for temp2
int sensorTempAmbPin = A2; // select the input pin for temp_ambient
int sensorExtVrefPin = A3; // select the input pin to measure external AD780, 3.00v half value, 2x 1k
int sensorExt5vPin = A4; // select the input pin to measure 5v rail 40% value via 1.5k and 1k Resistors
int ledPin = 13; // select the pin for the LED
#define ARRAY_LENGTH 96
#define ARRAY_LENGTH_RPM 2880 // elements of RPM array
#define VoltsPerBit 0.002930 // external Vref, AD780,3.00v
#define Adj 0.9 // adjustment factor for temperature reading accuracy 0014650
#define LoadResistor 4870 // Load resistor for temp sensor AD594, 1ua/deg K, 4870 ohms
#define NumberOneSecBetweenReadings 1
#define NumberRPMBetweenTemps 3 // 20 5 min = 300sec = 300/NumberOneSecBetweenRPM
#define NumberOneSecBetweenRPM 1 // 15
int sensorValueTemp1[ARRAY_LENGTH]; // temperature(degF) coming from the sensor
int sensorValueTemp2[ARRAY_LENGTH] ; // temperature(degF) coming from the sensor
int sensorValueTempAmb[ARRAY_LENGTH] ; // temperature(degF) coming from the sensor
unsigned int sensorRPM[ARRAY_LENGTH_RPM] ; // RPM values coming from 3ph voltage
unsigned int temp_RPM = 0;
unsigned int NumberOfBlips = 0;
long int RPMsubArray[60 * NumberOneSecBetweenReadings+1]; //average before report array
long int RPMAverager = 0;
#define NumTurbinePoles 42
#define ABS_MAX_RPM 4000
//int sensorValueCircularTest[ARRAY_LENGTH]; // test
int sensorBitsTemp1 = 0; //ADC conversion bits
int sensorBitsTemp2 = 0;
int sensorBitsTempAmb = 0;
int ExtVrefBits = 0;
int Ext5vBits = 0;
float MicroAmps = 0; // temp variable for temperature calculation
float temp7 = 0;
int temp_index = 0;
int temp_out_index = 0;
int array_index = 0;
int last_index = 0; //
int temp_cntr = 0;
int temp_Temp_cntr = 0;
short Temp_flag = 0;
int DelayTime = 0;
int idx = 0;
int temp_val = 0;
int temp_index_RPM = 0;
int temp_out_index_RPM = 0;
int array_index_RPM = 0;
int last_index_RPM = 0;
int temp_RPM_cntr = 0;
short RPM_flag = 0;
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE
IPAddress ip(192, 168, 1, 19);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
//setup for RPM measurement
// period of pulse accumulation and serial output, milliseconds
#define MainPeriod 100
long previousMillis = 0; // will store last time of the cycle end
volatile unsigned long duration=0; // accumulates pulse width
volatile unsigned int pulsecount=0;
volatile unsigned long previousMicros=0;
// declare the ledPin as an OUTPUT:
pinMode(ledPin, OUTPUT);
analogReference(EXTERNAL);
attachInterrupt(0, myinthandler, RISING); // setup interrupt
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
delay(1000); // 1 sec
temp_RPM_cntr++;
if (temp_RPM_cntr >= NumberOneSecBetweenRPM)
temp_RPM_cntr = 0; // wait till reading trigger
RPM_flag = 1;
array_index_RPM++;
if (temp_Temp_cntr > NumberRPMBetweenTemps)
temp_Temp_cntr = 0;
Temp_flag = 1;
array_index++;
if (array_index >= ARRAY_LENGTH) // make arrays circular
array_index = 0;
if (array_index_RPM >= ARRAY_LENGTH_RPM) // make array circular
Serial.print(temp_Temp_cntr);
Serial.print(" ");
Serial.print(temp_RPM_cntr);
Serial.print(" ");
Serial.print(Temp_flag);
Serial.print(" ");
Serial.print(RPM_flag);
Serial.print(" ");
Serial.print(currentMillis);
Serial.print(" "); // separator!
Serial.println("
//RPM stuff
if (currentMillis - previousMillis >= MainPeriod)
Serial.println("
//previousMillis = currentMillis;
previousMillis += MainPeriod;
// need to bufferize to avoid glitches
noInterrupts();
unsigned long _duration = duration;
unsigned long _pulsecount = pulsecount;
duration = 0; // clear counters
pulsecount = 0;
interrupts();
float Freq = 1e6 / float(_duration);
Freq *= _pulsecount; // calculate F
if (RPM_flag) // take a reading
sensorRPM[array_index_RPM] = Freq * 60 * 2 / NumTurbinePoles; // external /2 in hardware compensation
// output time and frequency data to RS232
Serial.print(Freq);
Serial.print(" ");
//Serial.print(_pulsecount);
Serial.print(sensorRPM[array_index]);
Serial.print(" ");
Serial.println(_duration);
temp_Temp_cntr++;
RPM_flag = 0;
if (Temp_flag)
// temperature code
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
// client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.print("EBRC Field Network, Temperature Monitor Page ");
client.println("
client.print("Wind Turbine RPM ");
temp_out_index = last_index;
for ( temp_index_RPM = 0; temp_index_RPM <= last_index_RPM ; temp_index_RPM++ )
client.print(sensorRPM[temp_out_index_RPM]);
temp_out_index_RPM = temp_out_index_RPM -1;
client.print(", ");
temp_out_index_RPM = ARRAY_LENGTH_RPM;
for (int temp_index_RPM = 0; temp_index_RPM < (ARRAY_LENGTH_RPM - last_index_RPM) ; temp_index_RPM++ )
client.print(", ");
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
void myinthandler() // interrupt handler
unsigned long currentMicros = micros();
duration += currentMicros - previousMicros;
previousMicros = currentMicros;
pulsecount++;
