It seems I lost my progress from a couple of months ago during a data migration...
Here are the two sketches I have at present...
This one displays my text, and polls a single probe and sends the data to the serial monitor:
#include <OneWire.h>
#include <UTFT.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire ds(10); // on pin 10
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// convert the data to actual temperature
unsigned int raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// count remain gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
// Set the pins to the correct ones for your development shield
// Arduino Uno / 2009:
// Standard Arduino Uno/2009 shield : <display model>,A5,A4,A3,A2
// DisplayModule Arduino Uno TFT shield : <display model>,A5,A4,A3,A2
// Arduino Mega:
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ITDB32S,38,39,40,41);
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(BigFont);
void loop();
myGLCD.setColor(255, 0, 0);
myGLCD.print("Probe Location:", 319, 239, 180);
myGLCD.setColor(255, 255, 255);
myGLCD.print("Intake - ", 319, 220, 180);
myGLCD.print("560mm Res 1 - ", 319, 205, 180);
myGLCD.print("560mm Res 2 - ", 319, 190, 180);
myGLCD.print("VRM - ", 319, 175, 180);
myGLCD.print("BackPlate - ", 319, 160, 180);
myGLCD.print("PSU - ", 319, 145, 180);
myGLCD.print("PCH - ", 319, 130, 180);
myGLCD.print("Pump 1 - ", 319, 115, 180);
myGLCD.print("Pump 2 - ", 319, 100, 180);
myGLCD.print("Coolant - ", 319, 85, 180);
// myGLCD.setColor(0, 0, 255);
// myGLCD.print("0 degrees", 0, 16, 0);
// myGLCD.print("90 degrees", 319, 0, 90);
// myGLCD.print("180 degrees", 319, 239, 180);
// myGLCD.print("270 degrees", 0, 239, 270);
// myGLCD.setFont(SevenSegNumFont);
// myGLCD.setColor(0, 255, 0);
// myGLCD.print("45", 90, 100, 45);
// myGLCD.print("90", 200, 50, 90);
// myGLCD.print("180", 300, 200, 180);
while (true) {};
While this one polls all probes and sends the data to the serial monitor, but does not show my text (Obviously has not been input):
#include <UTFT.h>
// UTFT_Textrotation_Demo (C)2014 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the textrotation-functions.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
ds.reset_search();
delay(250);
return;
Serial.write(' ');
return;
switch (addr[0]) {
case 0x10:
type_s = 1;
case 0x28:
type_s = 0;
case 0x22:
type_s = 0;
default:
return;
ds.reset();
ds.select(addr);
ds.select(addr);
Serial.print(" ");
Serial.print(" ");
if (type_s) {
Serial.print(" Intake Temperature = ");
// Declare which fonts we will be using
