loop failure!
I've attached below some VERY simple code that should count the number of times a loop is run
int LoopCounter = 0;
  Serial.begin(57600);
  Serial.println("resetting");
  Serial.print("Loop counter = "); //for debugging
  Serial.println(LoopCounter);  //for debugging
  if (LoopCounter = 10){
    Serial.println("I should only see this sentence once!");
    LoopCounter = LoopCounter + 1;
  else {
It doesn't, and I can't figure out why. I simplified the code and intend to put some interesting stuff where the "sentence" is once this starts running as desired.
This is what my com port displays:
resetting
Loop counter = 0
Loop counter = 11
Loop counter = 11
Loop counter = 11
Ideally the code counts up from zero by ones.
What am I missing?
Should be:
 if (LoopCounter == 10)
Thanks!
The 2 hours spent debugging before I posted should reinforce the difference between arithmetic and comparison operators!
