Loop only runs once after Serial.read input
Hi all, I have a project that uses ARGB LED strips that toggles effects (using FastLED) based on a received Bluetooth command. The problem is that when the Bluetooth command is received by the Arduino + HC-05, the effect loop only runs once and then stops. How do I actually make it loop? Thanks!
char data = 0;
#include "FastLED.h"
#define NUM_LEDS 74
#define PIN 2
CRGB leds[NUM_LEDS];
void flash()
  digitalWrite(LED_BUILTIN, HIGH);
  delay(100);
  digitalWrite(LED_BUILTIN, LOW);
void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  setAll(0,0,0);
  for(int i = 0; i < NUM_LEDS+NUM_LEDS; i++) {
    // fade brightness all LEDs one step
    for(int j=0; j<NUM_LEDS; j++) {
      if( (!meteorRandomDecay) || (random(10)>5) ) {
        fadeToBlack(j, meteorTrailDecay );
    // draw meteor
    for(int j = 0; j < meteorSize; j++) {
      if( ( i-j <NUM_LEDS) && (i-j>=0) ) {
        setPixel(i-j, red, green, blue);
    showStrip();
    delay(SpeedDelay);
void fadeToBlack(int ledNo, byte fadeValue) {
 #ifdef ADAFRUIT_NEOPIXEL_H
    // NeoPixel
    uint32_t oldColor;
    uint8_t r, g, b;
    int value;
    oldColor = strip.getPixelColor(ledNo);
    r = (oldColor & 0x00ff0000UL) >> 16;
    g = (oldColor & 0x0000ff00UL) >> 8;
    b = (oldColor & 0x000000ffUL);
    r=(r<=10)? 0 : (int) r-(r*fadeValue/256);
    g=(g<=10)? 0 : (int) g-(g*fadeValue/256);
    b=(b<=10)? 0 : (int) b-(b*fadeValue/256);
    strip.setPixelColor(ledNo, r,g,b);
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   leds[ledNo].fadeToBlackBy( fadeValue );
 #endif
void showStrip() {
    // FastLED
    FastLED.show();
  #endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
    // FastLED
    leds[Pixel].r = red;
    leds[Pixel].g = green;
    leds[Pixel].b = blue;
  #endif
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
  FastLED.addLeds<WS2812, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  setAll(0,0,0);
  pinMode(LED_BUILTIN, OUTPUT);
  if(Serial.available() > 0)      // Send data only when you receive data:
    data = Serial.read();
    Serial.println(data);
    if (data == 51)
      meteorRain(0xff,0xff,0xff,10, 64, true, 30);
      Serial.println("Meteor");
      flash();
Change this line Serial.println(data); to Serial.println(data, HEX);. Do you get what you expected? Or do you get more?
If you're not only sending '3' but also a <CR> or <LF> your data will no longer be '3' and if (data == 51) will no longer be true.
If I do that, it prints 33 instead of 3, then after meteorRain is called and finished, it prints Meteor. Then the loop stops.
i get the following output when i run your code and enter "123" and then "456"
(i don't see any Bluetooth code)
1
2
3
Meteor
4
5
6
Bluetooth is being read, that's what the Serial.read is from
  • Use a flag, with default value to false.
  • Set it to true when the command is received.
  • Move the meteorRain call in the main loop, and call it only if the flag value is true.
  • Set the flag value to false when you want to stop the effect.
The meteorRain function is a blocking function, not ideal.
  static bool effect = false;
    if (data == 51)
      effect = true;
      flash();
  if ( effect == true )
