Lora ra-02 sx1278 to arduino nano
im currently testing lora-based communication for a small project. my goal is to make them work so that i can advance to the next stage of my project. im using sx1278 ra-02 ai thinker connected to an Arduino nano. at first, i tried direct wiring. i know that move was risky and i wanna know if i can make this work now since the module initializes perfectly now that i am using 8channel logic level converter.
tx code
#include <LoRa.h>
// Pin definitions for Arduino Nano + TXS0108E + RA-02
#define LORA_SS   10
#define LORA_RST  2
#define LORA_DIO0 3
unsigned long counter = 0;
  while (!Serial);
  Serial.println("LoRa Sender");
  LoRa.setPins(LORA_SS, LORA_RST, LORA_DIO0);
  // Initialize LoRa at 433 MHz
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  // Lower bandwidth → more reliable on Nano
  LoRa.setSignalBandwidth(125E3);
  LoRa.setSpreadingFactor(9);
  LoRa.setCodingRate4(5);
  Serial.println("LoRa initialized successfully!");
  Serial.print("Sending packet: ");
  Serial.println(counter);
  LoRa.beginPacket();
  LoRa.print("Hello ");
  LoRa.print(counter);
  LoRa.endPacket();
  counter++;
  delay(5000);
rx code
#include <LoRa.h>
#define LORA_SS   10
#define LORA_RST  2
#define LORA_DIO0 3
  while (!Serial);
  Serial.println("LoRa Receiver");
    while (1);
  Serial.println("LoRa Receiver Ready");
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    Serial.print("Received packet: ");
    while (LoRa.available()) {
      Serial.print((char)LoRa.read());
    Serial.print("  RSSI: ");
    Serial.println(LoRa.packetRssi());
what im suspecting is the length of my adapter and wires, i used 60cm long adapter to connect to whip antenna, 20cm wires for connection.
thank you for help
Hand-draw the wiring diagram and post a picture of that.
I don;t think I understand the 60cm and 20cm comment, With all radios and especially Lora those lengths seem like a major problem. Maybe if you draw a picture of the connect between the antenna and Lora TX board it would be easier to understand.
do both transmitter and receiver initialize OK but there is no communication?
show serial monitor outputs (as text not screen images)?
