when I was a kld we called this a Dick Tracy wrist radio. It's right up there with flying cars in the "if you know enough to think it through you stop thinking about it in one minute" category.
U.S. FCC regulatory domain: LoRa is about sending 64 bit packets. total on air time in one day: 30 seconds
antennas: optimum transfer of RF energy to air requires a half wave antenna. LoRa in the US uses the 23 CM band. half wave = 12.5 CM =5" = a 2.5" ground plane and a 2.5" radiator. if that is all gibberish, consider getting an amateur radio license before you start experimenting with radio. another money sucking technical pastime. there are so many 7 year old hams it is no longer newsworthy.
Oh yeah. You mean like the cellular WiFi hotspots? But then I might as well just skip the WiFi part and use SIM7600, but then its just phone calls; not so much a walkie talkie. That was my thought process
I figured one person would press a PTT button, speak, and then release it. Then the next person can do the same. You could also address the correct person when you speak (such as "Hey Bob"), that way they know who youre speaking to.
I'm also new to radio stuff (I only have a bad experience with NRF24L01), which definitely doesnt help. Just to clarify, LoRa frequency range is 915mHz in North America, right? And what's the difference between "LoRa" and "radio" modules?
I just realized that I already own several Retevis RT6 Walkie Talkies. They can operate at up to 5W. How on earth do they do that? Could I just make the same exact thing, but much smaller? I don't mind that antenna size; i.e. I can make do with it.
Yes it is. I am using an Arduino as the main board. If the Nano ends up being too big, then ill probably use a Atmega with the Arduino Bootloader. I mean, technically the radio questions isn't "Arduino" related
They do it by having a battery that is capable of providing the more than 5W of power for them to operate.
You need to understand how radio waves and signal processing in a transceiver work?
