Hi there!
While I was measuring with noisy ECG signals, I need something that take cares of filtering the measured signals.
I came across the following filter library: Arduino-signal-filtering-library
It seems pretty easy to create a filter with this... It sounds really nice, it generates some code, and we need to change the libraries with the generated code? Anyhow... after editing my library files with the generated code I encountered several errors:
such like:
enabled in File > Preferences.
Arduino: 1.0.5-r2 (Windows NT (unknown)), Board: "Teensy 3.1"
In file included from newFilter.ino:4:0:
C:\Arduino\libraries\Filter/newFilter.h:12:10: error: ISO C++ forbids declaration of 'filter' with no type [-fpermissive]
newFilter:6: error: cannot declare variable 'Filter' to be of abstract type 'newFilter'
C:\Arduino\libraries\Filter/newFilter.h:9:7: note: because the following virtual functions are pure within 'newFilter':
In file included from C:\Arduino\libraries\Filter/newFilter.h:7:0,
C:\Arduino\libraries\Filter/Filter.h:20:17: note: virtual int Filter::run(int)
newFilter.ino: In function 'void setup()':
newFilter:14: error: 'class newFilter' has no member named 'begin'
C:\Arduino\libraries\Filter/Filter.h: In function 'void loop()':
C:\Arduino\libraries\Filter/Filter.h:20:17: error: 'virtual int Filter::run(int)' is private
newFilter:20: error: within this context
Anyone knows what's causing this? Or how to implement the generated code into a new library file? It's not very clear to me what i actually need to change?
At this moment i have edited 'newFilter.h' to this:
// Arduino Signal Filtering Library
// Copyright 2012-2013 Jeroen Doggen (jeroendoggen@gmail.com)
#ifndef newFilter_h
#define newFilter_h
#include <Arduino.h>
#include <Filter.h>
class newFilter : public Filter
public:
newFilter()
for(int i=0; i <= 10; i++)
v[i]=0.0;
private:
float v[11];
public:
float step(float x) //class II
v[0] = v[1];
v[1] = v[2];
v[2] = v[3];
v[3] = v[4];
v[4] = v[5];
v[5] = v[6];
v[6] = v[7];
v[7] = v[8];
v[8] = v[9];
v[9] = v[10];
v[10] = (2.766929730595e-3 * x)
+ ( -0.0808708884 * v[0])
+ ( 0.8744889062 * v[1])
+ ( -4.4332135268 * v[2])
+ ( 13.8481537992 * v[3])
+ (-29.4860113999 * v[4])
+ ( 44.7006874561 * v[5])
+ (-48.8754142978 * v[6])
+ ( 38.0698269619 * v[7])
+ (-20.2086326211 * v[8])
+ ( 6.5906492691 * v[9]);
return
(v[10] - v[0])
+5 * (v[2] - v[8])
+10 * (v[6] - v[4]);
#endif
