lua script is crashing linux side
For checking if Yun is in Wifi range i'm using this lua script:
#!/usr/bin/lua
local function get_wifi_info(network, iface, accumulator)
  local net = network:get_wifinet(iface)
  if net then
    local dev = net:get_device()
    if dev then
      accumulator["quality"] = net:signal_percent()
    end
  end
end
local function collect_wifi_info()
  local network = require"luci.model.network".init()
  local accumulator = {}
  get_wifi_info(network, "wlan0", accumulator)
  return accumulator
end
local info = collect_wifi_info()
if info.quality then
  print(info.quality)
end
It is giving back the signalstrength of wifi.
At the sketch side im using this code:
boolean wifiConnected() {
  String strength;
  Process p;        // Create a process and call it "p"
  p.runShellCommand("/mnt/sda1/wifi-status.lua");
  p.run();      // Run the process and wait for its termination
  while (p.available()>0) {
    char c = p.read();
    strength += c;
  // Ensure the last bit of data is sent.
  Serial.flush();
  #ifdef debug
  Serial.println("Wifi Signalstaerke: " + strength);
  #endif
  if (strength == "") {
    return false;
  if (strength.toInt() > 0) {
      return true;
  else {
    return false;
It's giving back TRUE if signalstrenght is more then zero.
Im using this in loop to decide, if yun should upload data or store data in file. After a while, sometimes hours, the hole yun is blocking. The white led, who is showing if wifi is ok, is going off and i can not access yun anymore until i reset it.
What could be going wrong? Thank's for some ideas.
The RunShellCommand method already executes the command, you don't need to call run(). I'd replace it with
Process p;
p.begin("/mnt/sda1/wifi-status.lua");
p.run();
Other things seem fine to me.
Thank's for the advice. I removed the RunShellCommand.
For 2 weeks of testing it worked well. But today i got the same proplem. Executing the lua script is crashing linux side.
Maybee someone knows the reason.
cello:
cello,
This line does not look syntactically correct.
Jesse
