Hello all,
I'm trying to shift eight bits through my M74HC164B1 shift register (the datasheet is here: http://www.datasheetarchive.com/M74HC164B1-datasheet.html). It has two data output pins and one clock output pin. I have shift register pins 1, 14, and 9 wired to HIGH on my breadboard, pin 7 wired to LOW on my breadboard, pin 2 (data output) wired to digital pin 9 on my arduino, pin 8 (clock output) wired to pin 2 on my arduino, and the output pins on the shift register wired to their respective LEDs. The 5V and GND pins are wired to the correct power rails on my breadboard.
I then tried uploading this program:
int data = 9; int clock = 2;
void setup() { pinMode(clock, OUTPUT); // make the clock pin an output pinMode(data , OUTPUT); // make the data pin an output shiftOut(data, clock, LSBFIRST, B10101010); // send this binary value to the shift register }
void loop(){} // empty loop for now
Nothing lit up though. Could someone please help me out? I want to shift a bit through and have it show up on my LEDs. Thanks!
