here's the wifi code from my model RR node
look at _wifiInit(), wifiSend() and _wifiCfgUdp() where _wifiMsg() is specified as a callback
functions prefixed with '_' would be private if this were a class
#ifdef ESP32
# include <WiFi.h>
#elif defined(ESP8266)
# include <ESP8266WiFi.h>
#endif
#include "AsyncUDP.h"
#include "eeprom.h"
#include "node.h"
#include "signals.h"
#include "wifi.h"
int dbgWifi = 1;
static void _wifiScan (void);
static void _wifiMsg (const char *msg);
// WiFiClient wifi;
AsyncUDP udp;
char host [STR_SIZE] = "";
char ssid [STR_SIZE] = "";
char pass [STR_SIZE] = "";
static int port = 4445;
enum { ST_NUL, ST_INIT, ST_CHK, ST_CFG_UDP, ST_UP, ST_ERROR };
const char *wifiStStr [] = {
"ST_NUL",
"ST_INIT",
"ST_CHK",
"ST_CFG_UDP",
"ST_UP",
"ST_ERROR"
int state = ST_NUL;
int stateLst = ST_NUL;
static bool
_wifiCheck (void)
static int fails = 0;
static unsigned long msecLst = 0;
if ( (msec - msecLst) < 1000)
return false;
msecLst = msec;
printf (" %s:", __func__);
#if 0
if (6 <= fails) {
_wifiScan ();
return false;
#endif
if (WL_CONNECTED != WiFi.status ()) {
printf (" not connected\n");
fails++;
return false;
IPAddress ip = WiFi.localIP ();
printf (" connected %d:%d:%d:%d\n", ip [0], ip[1], ip [2], ip[3]);
return true;
// https://arduino.clanweb.eu/udp-control-esp32.php?lang=en
static void
_wifiCfgUdp (void)
printf (" %s:\n", __func__);
if (udp.listen (port)) {
Serial.print (" UDP Listening on IP: ");
Serial.println (WiFi.localIP ());
udp.onPacket ([] (AsyncUDPPacket packet) {
#if 0
Serial.print ("UDP Packet Type: ");
Serial.println (packet.isBroadcast ()
? "Broadcast"
: packet.isMulticast () ? "Multicast" : "Unicast" );
Serial.print (" From: ");
Serial.print (packet.remoteIP ());
Serial.print (":");
Serial.println (packet.remotePort ());
Serial.print (" To: ");
Serial.print (packet.localIP ());
Serial.print (":");
Serial.println (packet.localPort ());
Serial.print (" Length: ");
Serial.println (packet.length ());
Serial.print (" Data: ");
Serial.write (packet.data (), packet.length ());
Serial.println ();
#endif
_wifiMsg ((const char *) packet.data ());
// connect to wifi
void _wifiInit (void)
_wifiScan ();
WiFi.mode (WIFI_STA);
WiFi.hostname (host);
printf ("%s: ssid %s, pass %s\n", __func__, ssid, pass);
WiFi.begin (ssid, pass);
static void
_wifiMsg (
const char *msg)
sigMsg (msg);
void
wifiReset (void)
printf ("%s: ssid %s, pass %s, host %s\n", __func__, ssid, pass, host);
state = ST_NUL;
// https://openlabpro.com/guide/scanning-of-wifi-on-esp32-controller/
static void
_wifiScan (void)
printf ("%s:\n", __func__);
// WiFi.scanNetworks will return the number of networks found
WiFi.mode (WIFI_OFF);
int nNet = WiFi.scanNetworks ();
if (nNet == 0) {
printf (" %s: no networks found\n", __func__);
else {
printf (" %s: %2d networks found\n", __func__, nNet);
if (0 > nNet)
nNet = -nNet;
for (int i = 0; i < nNet; ++i) {
printf (" %s: %2d - %s (%d) %s\n", __func__, i,
WiFi.SSID (i).c_str (),
WiFi.RSSI (i),
WiFi.encryptionType (i) == WIFI_AUTH_OPEN ? "open" : "locked");
// common routine for sending strings to wifi and flushing
void
wifiSend (
const char* msg )
if (ST_UP != state)
return;
if (dbgWifi) {
printf ("wifiSend: %s\n", msg);
udp.broadcast (msg);
void
wifiMonitor (void)
if (stateLst != state)
printf ("%s: %d %s\n", __func__, state, wifiStStr [state]);
stateLst = state;
switch (state) {
case ST_NUL:
if (ssid [0])
state = ST_INIT;
else {
printf ("%s: no SSID\n", __func__);
state = ST_ERROR;
case ST_INIT:
_wifiInit ();
state = ST_CHK;
case ST_CHK:
if (_wifiCheck ())
state = ST_CFG_UDP;
case ST_CFG_UDP:
_wifiCfgUdp ();
state = ST_UP;
case ST_UP:
case ST_ERROR:
default:
