Make a arduino uno and a HC-05 to act as a bluetooth module for pc
My pc headset started to have a little crack on the main band over the head so I have a Uno,HC-05 module and a bluetooth headset and I have in plan to use the Uno and HC-05 as a bluetooth module for my pc (add Bluetooth connection to my pc) Is it possible?
What does Google on UNO + audio say?
You might need a more powerful controller if You want clear music.
there isnt a method so i can wire the HC-05 to a usb port and plug it in my pc?
No. You would need one specially designed for that.
There are several different protocols used by bluetooth.
See this tutorial for more details.
The HC-05 uses SPP (Serial Port Protocol).
Headphones use a different one, so unfortunately it won't work.
