Make a servomotor and a potentiometer work in parallel
Hello!
This is my very first project with Arduino, it is an automate created from old typewriter parts, in its eye there is an rgb led connected to a 10k potentiometer (to change the color), and two servomotors in its head, operated by an ultrasonic sensor HC-SR04.
All this is managed by an Arduino Nano ATmega328P clone.
The task of the automaton is to trigger moving parts in its head when we approach within a meter, and I would like us to be able to adjust the color of the eye.
Atually it only works separetely.
Being new to programming I mixed several codes and did a lot of research on the net to find a solution to my problem, especially on the arduino forum, without success yet.
I have two codes compiled and running:
The first, below, operates the servomotors in a loop, without using the HC-SR04 sensor. But it can adjust the rgb LED.
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int pos = 0;
void ledRVBpwm(int pwmRouge, int pwmVert, int pwmBleu);
const int ledRouge=3;
const int ledVert=5;
const int ledBleu=6;
int tension, val;
  pinMode (ledVert,OUTPUT);
  pinMode (ledRouge,OUTPUT);
  pinMode (ledBleu,OUTPUT);
  myservo1.attach(9);
  myservo2.attach(10);
  for (pos = 50; pos <= 110; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo1.write(pos);              // tell servo to go to position in variable 'pos'
    myservo2.write(pos);
    delay(30);                       // waits 15ms for the servo to reach the position
  for (pos = 110; pos >= 50; pos -= 1) { // goes from 180 degrees to 0 degrees
    delay(20);                       // waits 15ms for the servo to reach the position
  tension = analogRead(A0);
val = map(tension,0,1023,0,2*255);
if( val < 255)
ledRVBpwm(0,val,255-val);
if( val >= 255 && val <= 2*255)
ledRVBpwm(val-255, 255-(val-255),0);
void ledRVBpwm(int pwmRouge, int pwmVert, int pwmBleu) { // reçoit valeur 0-255 par couleur
analogWrite(ledRouge, pwmRouge);
analogWrite(ledVert, pwmVert);
analogWrite(ledBleu, pwmBleu);
The second, here, triggers the two servomotors via the HC-SR04 sensor.
#include<Servo.h>
Servo myservo1;
Servo myservo2;
const int trigPin = 2;
const int echoPin = 11;
myservo1.attach(9);
long duration, cm;
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
// the condition for the distance
if ( cm > 1 && cm < 100)
myservo1.write(50);
myservo2.write(50);
delay(2000);
else if ( cm > 100)
myservo1.write(110);
myservo2.write(110);
delay(100);
myservo1.write(50);
myservo2.write(50);
delay(100);
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToCentimeters(long microseconds) {
return microseconds / 29 / 2;
I try to get a mixture of the two, because I want to be able to activate the servomotors via the ultrasonic sensor, and also that we can set the led to the color of our choice. At the moment I am there:
#include<Servo.h>
Servo myservo1;
Servo myservo2;
int pos = 0;
int tension, val;
myservo1.attach(9);
long duration, cm;
myservo1.write(50);
myservo2.write(50);
delay(2000);
else if ( cm > 100)
delay(100);
myservo1.write(50);
myservo2.write(50);
delay(100);
Serial.print(cm);
Serial.print("cm");
delay(100);
if( val < 255)
and here is the detailed error message
sketch_mar31a:108:1: error: 'tension' does not name a type
sketch_mar31a:110:1: error: 'val' does not name a type
sketch_mar31a:112:1: error: expected unqualified-id before 'if'
 if( val < 255)
sketch_mar31a:115:1: error: expected unqualified-id before 'if'
sketch_mar31a:118:1: error: expected declaration before '}' token
exit status 1
Thank you for your help and advices to all of you!
check your {} and functions (press ctrl-T in the IDE to indent) you'll see that the code is not right
val = map(tension, 0, 1023, 0, 2 * 255);
if ( val < 255)
  ledRVBpwm(0, val, 255 - val);
if ( val >= 255 && val <= 2 * 255)
  ledRVBpwm(val - 255, 255-(val - 255), 0);
seems to be hanging outside any function
Thank you for such a fast answer! I'm doing this.
I've added an integer for the potentiometer, but i don't get how i can link it to the value of the tension...
#include<Servo.h>
Servo myservo1;
Servo myservo2;
int potPin = A0; // select the input pin for the potentiometer
int tension, val; // variable to store the value coming from the potentiometer
const int ledRouge = 3;
const int ledVert = 5;
const int ledBleu = 6;
  pinMode (ledVert, OUTPUT);
  pinMode (ledRouge, OUTPUT);
  pinMode (ledBleu, OUTPUT);
  myservo1.attach(9);
  long duration, cm;
    myservo1.write(50);
    myservo2.write(50);
    delay(2000);
  else if ( cm > 100)
    delay(100);
    myservo1.write(50);
    myservo2.write(50);
    delay(100);
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
if ( val < 255)
aka
val = analogRead(A0) / 2;
Assuming "tension" == "voltage", the voltage of what?
It is supposed to be the voltage of the current going through the potentiometer...
Do you need the voltage, or just some value proportional to the pot's position?
Thank you for your answer: i just need a proportional value, not a specific voltage ...
I found this sketch
// Init the Pins used for PWM
const int redPin = 9;
const int greenPin = 10;
const int bluePin = 11;
// Init the Pins used for 10K pots
const int redPotPin = 0;
const int greenPotPin = 1;
const int bluePotPin = 2;
// Init our Vars
int currentColorValueRed;
int currentColorValueGreen;
int currentColorValueBlue;
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
// Read the voltage on each analog pin then scale down to 0-255 and inverting the value for common anode
  currentColorValueRed = (255 - map( analogRead(redPotPin), 0, 1024, 0, 255 ) );
  currentColorValueBlue = (255 - map( analogRead(bluePotPin), 0, 1024, 0, 255 ) );
  currentColorValueGreen = (255 - map( analogRead(greenPotPin), 0, 1024, 0, 255 ) );
// Write the color to each pin using PWM and the value gathered above
  analogWrite(redPin, currentColorValueRed);
  analogWrite(bluePin, currentColorValueBlue);
  analogWrite(greenPin, currentColorValueGreen);
But it works with 3 potentiometers... and with specific voltage.
I finally founded some help, and i have a code running. It was mainly a lack of fonction definition.
#include <Servo.h>
// Declaration des variables globales
Servo myservo1;
Servo myservo2;
int pos = 0;
int tension, val;
// Declaration  des constantes globales
// Declaration des fonctions
void commande_servos_1_2();
void commande_led();
long microsecondsToCentimeters(long microseconds);
  // Brochage des composants
  pinMode (trigPin, OUTPUT);
  pinMode (echoPin, INPUT);
  myservo1.attach(9);
  // Activation de la liaison serie
  // Programme principal
  commande_led();
void commande_led() {
  // modifier la couleur de la LED RVB selon valeur potentiometre
  if (val < 255)
  if (val >= 255 && val <= 2*255)
void commande_servos_1_2() {
  // declenche les deux servomoteurs via le capteur HC-SR04.
  long duration, cm;
  delay(100);
  Serial.print("duree : ");
  Serial.print(duration);
  Serial.print(" - distance : ");
  Serial.print(cm);
  if (cm > 1 && cm < 100) {
    myservo1.write(50);
    myservo2.write(50);
    delay(2000);
  else if (cm > 100) {
    delay(100);
  else  {
    myservo1.write(50);
    myservo2.write(50);
    delay(100);
  // DEBUG SERIE : distance en cm calculee
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
  // convertis une duree en distance
  // Controle de la led RVB : valeurs de 0 a  255
beruart:
Why didn't the Arduino build process provide one?
Technically in C++ it's required to define what you use before you use it, so yes it would make sense to either declare the signature of the functions (or the functions themselves) before setup() and loop() but the Arduino IDE will have your back and during the sketch analysis process (if it's a .ino) will create the declaration for you automagically.
As a simple proof, remove them and you'll see it compiles totally fine without
