I want to controll red diode with a comand, blue diode with a comandand same with green. 3 different if statements. I want it as basic as possible so I can understand the code
const int RED = 9;
const int GREEN = 8;
const int BLUE = 7;
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
digitalWrite(RED, HIGH);
digitalWrite(GREEN, HIGH);
digitalWrite(BLUE, HIGH);
Hello babynisse
It seems to be a school assigment, isn´t it?
Show your recent attemps to see how we can help.
my attempt is in my post. I don't understand how to do it. do you have some examples?
If you open the IDE, and click on "files" you'll see a drop-down with "examples".
Enjoy!
I can´t see any attempt to use the if() instrucution.
Do you have to use this instruction?
Switch()/case would be more suitable.
yes its a switch case task. we didnt get any lecture for it.
the preferred method in this forum is:
put it some own effort (googling finding an example) and then ask a specific question about a specific line of code
Make LED light up from serial monitor
Arduino switch case example code
Add the following codes at the appropriate place of your sketch of post #1 to establish that Red LED turns ON when you send R from the InputBox of SM.
byte n = Serial.available();
if (n != 0)
char y = Serial.read();
if (y == 'R')
I'm interested in the exercise-text you received. Would you mind posting the text of the exercise you got from your teacher? I want to make a suggestion from there. (after reading the exercise-text)
best regards Stefan
its in norwegian so it may not help?
i cant type in serial monitor now? You know why that is
You upload sketch in UNO; open SM; bring cursor in the InputBox of SM; now enter/type R and then click on the Send Button. The RED LED should turn ON.
I simply will use google translate
Jeg bruker bare google translate
google is always worth a five minute search.
I got a
full hit
= a democode that does almost exactly what you would like to have
Post the latest sketch into which you have included the codes of post #8 and have uploaded.
const int RED = 9;
const int BLUE = 7;
if (n != 0)
if (y == 'R')
Is the sketch of post #17 working? If not, what is the problem? Do you have an Arduino UNO?
