I did posted this before but it wasn't very constructive because I lacked information at the time. Hopefully I have everything now. I need help, I am new to Arduino and I want to make sure I don't spend the money and turns out that I did something wrong/it wont be able to work.
I want to make a remote control Arduino to turn a motor on and off. It is a power window motor (the one you use for your car) and it is being powered by a car battery. I want to turn it on and off, that simple.
This is what I am using for the remote.
http://www.amazon.com/TOOGOO-240VAC-125VAC-28VDC-JQC-3F/dp/B00H3W3UA0/ref=sr_1_9?ie=UTF8&qid=1426121812&sr=8-9&keywords=relay
This is the relay
There isn't a max voltage that can go through that relay, right? Do I understand this correctly? Will this work or am I going to mess up my board?
