I am thinking of making a solder paste dispenser similar to the one in the link YouTube video.
Trying to get my head around how the piston is connected to the threaded motor shaft.
I think the rubber piston's friction against the syringe wall keeps the movement balanced.
I think the piston is just connected to a simple threaded rod that screws into the threaded brass sleeve. I assume the friction of the rubber against the cylinder wall keeps the piston from rotating.
You'll need a stepper motor or an encoder to get repeatable precise movement. That's a DC gearmotor of
some sort. That may be good enough by controlling the time of operation, I only know the original
design uses a stepper and it looks to work well.
I was going to try to see what kind of results I would get from this Swiss gear motor.
It is ~21 seconds per revolution at 5 volts, a bit slow. ~8 sec at 10V.
I do have several small steppers to try for version two.
I am getting too old, decided to order from Mike, the YouTube author.
Will use it for solder/flux pastes and single drop application such as solvent gluing etc.
