Making two if Statements work at the same time
Hi everyone, just want to ask how am I suppose to make two if statements to operate at the same time?
I mean in this setup,
there are two level sensors that act as input,
if they are triggered, they will trigger their corresponding pumps.
however, the result is this;
the if statement #2 does not operate while the if statement 1 is satisfied/triggered.
how can I make these two statements independent from each other?
const int level1 = 2;
const int level2 = 3;
const int pump1 = 4;
const int pump2 = 5;
  pinMode(level1, INPUT_PULLUP);
  pinMode(level2, INPUT_PULLUP);
  pinMode(pump1, OUTPUT);
  pinMode(pump2, OUTPUT);
  int state1 = digitalRead(level1);
  int state2 = digitalRead(level2);
    if(state1==0)
      digitalWrite(pump1, HIGH);
    digitalWrite(pump1, LOW);
    if(state2==0)
      digitalWrite(pump2, HIGH);
      digitalWrite(pump2, LOW);
You seem to have lost track of where your braces are.
The 2nd if() is part of the else of the 1st if().
    if(state1==0)
// ------------------------ so why is this block inside of that else if you want them separate?
      if(state2==0)
// ---------------------------------------------------------------- hmmmm?
You may have another problem when you get that fixed.
If one pump fills and the other empties then you will make dueling pumps.
