- Serial Port Problems:
- The Arduino Nano ESP32 frequently switches between ports, sometimes appearing as COM8, and other times as "1-4 DFU port."
- The serial monitor often fails to connect, showing errors such as:
- "No monitor available for the port protocol DFU. Could not connect to 1-4 DFU port."
- "Port monitor error: command 'open' failed. Serial port busy. Could not connect to COM8 serial port."
- Unstable Behavior:
- The board often gets stuck in DFU mode and requires multiple resets to function normally.
- Even after successfully connecting to a COM port, the serial communication works inconsistently, with frequent failures to write or read data.
- Steps Taken:
- Tried changing USB cables and using different USB ports (avoiding hubs).
- Reinstalled drivers (CP210x/CH340) and updated the ESP32 board package in the Arduino IDE.
- Used the RESET button to force the board out of DFU mode.
- Tested the board on another PC, but the issues persist.
- Tested 2 other arduino nano esp32 but the issues persist.
