MAP function not working properly
Hi all,
First off I am new to arduino so please forgive me if this is a stupid question. I am trying to use the MAP function but it doesn't seem to be working correctly.
#include <dcmotor.h>;
DCMotor motor1(12,11,2);
int potPin = A9;
double orderAngle;
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(2,OUTPUT);
motor1.SetTurnSpeed(155);
if (Serial.available())
analogReadResolution(12);
orderAngle = Serial.parseFloat();
Serial.print("order Recieved");
Serial.println(orderAngle);
ObeyServoOrder(orderAngle);
PrintServoPosition(orderAngle);
void ObeyServoOrder(double orderAngle)
double potRest = (double)analogRead(potPin);
double currAngle = map(potRest,0,4095,0,360);
orderAngle = constrain(orderAngle,0,359);
while (abs(orderAngle - currAngle) > 1) //there is a posn error. my error tolerance = 5 degrees
potRest = (double)analogRead(potPin); //1023 * 10;
if (orderAngle > currAngle)
//turn right
Serial.print("Current");
Serial.print(currAngle);
Serial.print("Order");
Serial.print(orderAngle);
Serial.println("Turning Right");
motor1.SetTurnDirection(right);
motor1.Turn();
} else
//turn left
Serial.println("Turning Left");
motor1.SetTurnDirection(left);
motor1.Turn();
motor1.Stop(); //if there is no error, stop the motor
void PrintServoPosition(double orderAngle)
double potRest = (double)analogRead(potPin); //1023 * 10
Serial.print("Ordered Angle");
Serial.print("Position");
Serial.println(currAngle);
delay(50);
Here are the corresponding analog inputs for the corresponding 0-359 deg positions
OrderAngle = Pot position
90deg = 2682
150deg = 2258
180deg = 2111
240deg = 1766
270deg = 1589
330deg = 924
0 deg = 90
30deg = 3669
What do I need to do to get to go to the correct commanded positions?
Thank you so much,
Rob
I'm pretty sure that map doesn't work with floating point values. It might be best to do it the old fashioned way.
If you are using the built-in adc on the chip, your value should be more like this
double currAngle = map(potRest,0,1023,0,360);
not the way you have it.
Try that and see if it gives you the results you're looking for.
And as stated, map doesn't like floats so you may have to find another way to get your float value. something maybe like
int currAngle = map(potRest,0,1023,0,360);
double AngleVal = (currAngle * 0.001);
Bill
float currAngle = potRest * 360.0/1023.0; // instead of map ?
I'm using a Teensy 3.1 which is reading the pot in 12bit I tried all your examples, still getting bad results of not going to the correct location and sometimes different spots. I tested the pot with a little program it is very steady and accurate on the input side.
The semicolon is pointless here, include directives aren't C statements.
    analogReadResolution (12) ;
You should set the analog resolution once, in setup(), then read and discard
one analog reading to resynchronise the ADC hardware - you may be reseting the ADC
hardware everytime round loop with this and making analogRead() produce nonsense
(not sure, but certain changes to the ADC do require a read-and-discard afterwards).
737nut:
90deg = 2682
150deg = 2258
180deg = 2111
240deg = 1766
270deg = 1589
330deg = 924
0 deg = 90
30deg = 3669
Looking at those values there's no direct corelationship between them. If you add 30 to the pot angle you then get something that approaches a curve, but it's got a distinct kink in it.
The nearest I could come up with was
double currAngle = 6 * ( 360 - ( potRest + 30 ) ) + 1226;
//Now adjust for kink
   if ( currAngle < 1528 )
     currAngle = currAngle - (1528-currAngle);
But if markT is correct about you getting erroneous values (very likely), then this is going to be in vain.
Mark and Ken,
Thanks for the help, I will try tomorrow as I am away from the shop today. I agree, there is a strange correlation going on here. The strange part is it a compass instrument and the same scale 360degs. Maybe my pot has a bad spot? I'll do some more testing tomorrow.
Thanks again
Rob
Looking at those values again, it gives me the impression that you have a diode in the circuit with the pot. So at some critical point, it's forward voltage is being exceded and thus throwing the value.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Thanks It will help a lot.
Tom.... :slight_smile:
I'll draw it up when I get home. It's real simple though, Using the 3.3V out of the Teensy to one side of pot, Wiper on A9 for the analog in, and GND going to the Gnd on the Teensy. I swapped the power and GND yesterday on the pot to get it to match up to the range better. Although map function is supposed to work either way. The only place it is accurate is the 180deg point. Dead on everytime. The pot i'm using is 10K continuous turn high precision mil spec pot. I think it is all code related so I will make the changes tonight mentioned above.
Rob
737nut:
Rob
Actually, I did notice that my solution posted above, goes the wrong way. (I've used your value columns the wrong way around). I'll have a look at switching it.
I tried moving analogReadres(12) to setup, had no effect on ops.
I think i am going to switch to a magnetic position sensor that will do a true 360 reading. I did some testing last night and my dead spot is a little bigger than i originally thought. I have roughly a 10-15deg dead spot were the pot goes open.
I am going to use the AS5045 sensor so I will have to add some SPI code to read the 12bit position info from the sensor. I think this will make it work much better though.
Rob
Hi, circuit diagram of your existing setup please.
Tom....... :slight_smile:
TomGeorge:
Pot pin 1 goes to AGND on Teensy
Pot pin 2 goes to pin A9 (analog in from pot wiper)
Pot pin 3 goes +3.3Vdc from Teensy
Pin 11 and Pin 12 are DigitalWrite out to motor controller
Thats it, nothing more or nothing less to this simple circuit.
Rob
Also, if I do this 360/4095=.0879 If I take the current pot input * .0879 it matches up nicely with the Compass degrees. So can get rid of the mp function and insert this math instead? Not sure how or if it will work.
Rob
Hi
float currAngle = potRest * 360.0/4095; // instead of map ?
works because of simple maths.
You take the analog input (0 to 4095) and divide it by 4095
to find the fraction of a full resistance sweep of the pot you have dialed up.
You then multiply that fraction by 360, representing degrees in a full circle,
to get the amount of degrees your pot position represents.
So half way will be 2048 on the analog input, divided by 4095 is close to 0.5,
now 0.5 times 360 = 180 degrees of rotation output.
ps. I hope you realise that a continuous turn pot has a point where the wiper will change from 10k to zero K and start again?
You have to find this position to locate you zero degrees mechanical position of the pot.
