opus59
January 22, 2026, 1:03pm
1
I do not understand why pow(2,2) is given my a result of 3! What am I missing?
int value;
for (int i=0;i<4;i=i+1) {
value=int(pow(2,i));
Serial.println("Value: " +String(value));
Serial Log:
Value: 1 Value: 2 Value: 3 Value: 7
jim-p
January 22, 2026, 1:09pm
2
Not sure if it is the solution...
int()
will return the downward rounding (truncation).
So 3.99999999999 will yield 3
And 7.99999999 will yield 7
I do not know why pow(2,2) would yield 3.999999 instead of 4.0... ...since both integers have an exact representation as binary float. This may be caused by the implementation of pow(). It can take decimals as exponent, so it will treat 2 as 2.0 and might make a small rounding error somewhere.
Haven't looked at the implementation. Perhaps it uses ln() and e^x?
That makes sense and would explain...
opus59
January 22, 2026, 1:57pm
6
OK, that all makes sense (sort off). So my mistake is the use of int variables, I didn't expect that!
Have search for a way around, worst case would be a value table.
Thanks
What are your requirements? If they're only to raise "2" to an integral power, then a left shift is the way to go.
xfpd
January 22, 2026, 2:03pm
8
Binary representation of floating points as fractions into sign, base, mantissa and exponent.
opus59:
a way around
int base = 2, power = 16;
float result = 1;
for (int i = 0; i < power; i++) { // loop "power" times
result *= base; // recursive x = x * y
Serial.print(result, 0); // truncate decimal
@opus59
try the round() function
int value;
for (int i = 0; i < 4; i = i + 1)
value = round(pow(2,i));
gcjr
January 22, 2026, 4:35pm
10
robtillaart:
0 1
1 2
2 4
3 8
4 16
5 32
6 64
for (int i = 0; i < 7; i++) { // loop "power" times
printf (" %3d %6d\n", i, (int)( pow(2, i) +0.5));
jim-p
January 22, 2026, 5:11pm
11
If you spent spme time reading the Arduino language reference you would have expected it.
jim-p
January 22, 2026, 5:12pm
12
What is wrong with using floats?
There is no need for floats...
Just use round() to convert the resulting float to an integer...
Or write your own
int32_t intpow(int, int) function...
jim-p
January 22, 2026, 6:45pm
15
The function arguments are floats and the result is a double.
Why not just use the function the way it's supposed to be used.
If you call the func with 2 ints as arguments, they will be automatically promoted to float.
Nothing wrong with that...
@opus59
An integer only version int32_t intPower(int base, int exponent) would have some limits.
if the exponent is negative, the result is (probably) zero.
if the base is larger, overflow is near
if the exponent is larger, overflow is near.
(finding the practical limits is left as an exercise ;)
Gives compilation error in iDE 1.8.19.
exit status 1
'intPower' was not declared in this scope
Do I need to include any library file where the function is defined?
In this thread we have seen the limits of
float pow(float, float)
It will not yield exact answers...
So pow(2,3)==8 will be false...
And indeed, int32_t pow( int,int) will quickly overflow...
You might add a third argument reporting error codes...
int32_t pow(int, int, &int)
+1 (good idea)
Plus we might need int64_t quite fast…
It was left to OP to implement this not yet existing function...
