Hardware:
- Arduino UNO;
- Arduino Motor Shield Rev3;
- 4 wires stepper motor (0.9° step angle);
- uEye USB CCD camera;
- 12V power supply.
Goal:
The camera take several pictures once the motor move one step. The rotation range from -117 to 117 degree.
①The camera start capture; ②once the camera finish, send information to motor; ③and motor move to the next step; ④and then camera start capture again.
Question:
I try do simple serial communication from Matlab to Aruino, it works, but just don’t know how to send data from Arduino to Matlab, can anyone help me, plz?
Code in Arduino:
#include<Stepper.h>
const int stepsPerRevolution = 400;
const int dirA = 12;
const int dirB = 13;
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 9;
const int brakeB = 8;
int matlabData;
Stepper myStepper(stepsPerRevolution, dirA, dirB);
int x = 0;
int stepCount = 0;
void setup(){
pinMode(pwmA, OUTPUT);
pinMode(pwmB, OUTPUT);
pinMode(brakeA, OUTPUT);
pinMode(brakeB, OUTPUT);
digitalWrite(pwmA,HIGH);
digitalWrite(pwmB,HIGH);
digitalWrite(brakeA,LOW);
digitalWrite(brakeB,LOW);
myStepper.setSpeed(60);
if(Serial.available()>0)
matlabData=Serial.read();
delay(10);
if (matlabData==3)
delay(10);
myStepper.step(200);
delay(300);
if(matlabData==4)
delay(10);
myStepper.step(-200);
delay(300);
Code in Matlab:
ar = serial('COM4','BaudRate',9600);
fopen(ar);
fprintf(ar,'%s',char(3));
pause(20);
t = 5;
interval = 1;
ROIxcentre = 540;
ROIycentre = 380;
ROIsize = 300;
n = t/interval;
xstart = ROIxcentre - (ROIsize/2) + 1;
ystart = ROIycentre - (ROIsize/2) + 1;
xend = ROIxcentre + (ROIsize/2);
yend = ROIycentre + (ROIsize/2);
allImgs = zeros(ROIsize,ROIsize,n);
for i = 1:n
img = Camera(1);
imageDataROI = img(xstart:xend,ystart:yend);
figure(1)
imshow(imageDataROI,[0 255])
allImgs(:,:,i) = imageDataROI;
pause(interval)
end
allImgs = mat2gray(reshape(allImgs,ROIsize*ROIsize,t/interval));
fprintf(ar,'%s',char(4));
pause(5);
t = 3;
interval = 1;
ROIxcentre = 540;
ROIycentre = 380;
ROIsize = 300;
n = t/interval;
for i = 1:n
img = Camera(1);
figure(1)
pause(interval)
end
pause(5);
fclose(ar);
Code to initialize camera:
function out = Camera(noPics)
% Obtains single frame from camera
% Add NET assembly if it does not exist
% May need to change specific location of library
asm = System.AppDomain.CurrentDomain.GetAssemblies;
if ~any(arrayfun(@(n) strncmpi(char(asm.Get(n-1).FullName), ...
'uc480DotNet', length('uc480DotNet')), 1:asm.Length))
NET.addAssembly(...
'C:\Thorcam\DCx_Camera_SDK\Develop\DotNet\signed\uc480DotNet.dll');
end
% Create camera object handle
cam = uc480.Camera;
% Open 1st available camera
% Returns if unsuccessful
if ~strcmp(char(cam.Init), 'SUCCESS')
error('Could not initialize camera');
end
% Set display mode to bitmap (DiB)
if ~strcmp(char(cam.Display.Mode.Set(uc480.Defines.DisplayMode.DiB)), ...
'SUCCESS')
error('Could not set display mode');
end
% Set colormode to 8-bit RAW
if ~strcmp(char(cam.PixelFormat.Set(uc480.Defines.ColorMode.SensorRaw8)), ...
'SUCCESS')
error('Could not set pixel format');
end
% Set trigger mode to software (single image acquisition)
if ~strcmp(char(cam.Trigger.Set(uc480.Defines.TriggerMode.Software)), 'SUCCESS')
error('Could not set trigger format');
end
% Allocate image memory
[ErrChk, img.ID] = cam.Memory.Allocate(true);
if ~strcmp(char(ErrChk), 'SUCCESS')
error('Could not allocate memory');
end
% Obtain image information
[ErrChk, img.Width, img.Height, img.Bits, img.Pitch] ...
= cam.Memory.Inquire(img.ID);
error('Could not get image information');
end
% Acquire image
if ~strcmp(char(cam.Acquisition.Freeze(true)), 'SUCCESS')
error('Could not acquire image');
end
% Extract image
[ErrChk, tmp] = cam.Memory.CopyToArray(img.ID);
error('Could not obtain image data');
end
% Reshape image
img.Data = reshape(uint8(tmp), [img.Width, img.Height, img.Bits/8]);
imageData = double(img.Data).*checkerboard10(img.Width, img.Height);
fixed = conv2(imageData, [0 1 0;1 0 1;0 1 0]/4,'same');
RBmask = find(imageData == 0);
imageData(RBmask) = fixed(RBmask);
% imageData = img.Data;
% discard edges
imageData = imageData(2:img.Width-1,2:img.Height-1);
out = imageData;
% Close camera
if ~strcmp(char(cam.Exit), 'SUCCESS')
error('Could not close camera');
end
cam.Exit;
Many thanks!
