I am trying to use a Pixhawk 4 to send current information from the ESC to the Arduino Uno. I am using Understanding the Arduino Mavlink library | Lo.C.A.R.B. as a reference. By including mavlink.h at the top of the script, I have access to library_v1 under mavlink. Unfortunately, I want to use a header file only in library_v2 and I am having problems running this library.
In Mavlink.io (Messages (common) · MAVLink Developer Guide) I have found the header file I am looking for (ESC_STATUS (#291)) " mavlink_msg_esc_status.h, however, I am getting error messages including it and trying to use its variables ("Error compiling for board Arduino Uno.") I am able to use header files imported from mavlink.h such as mavlink_msg_gps_raw_int.h with no problems.
I would appreciate any help or advice getting this running. My code is below.
#include "mavlink.h"
#include "mavlink_msg_esc_status.h"
#include <SoftwareSerial.h>
#define RXpin 2
#define TXpin 3
SoftwareSerial SerialMAV(RXpin, TXpin); // sets up serial communication on pins 3 and 2
SerialMAV.begin(9600); //RXTX from Pixhawk (Port 19,18 Arduino Mega)
Serial.begin(9600); //Main serial port for console output
request_datastream();
MavLink_receive();
//function called by arduino to read any MAVlink messages sent by serial communication from flight controller to arduino
void MavLink_receive()
mavlink_message_t msg;
mavlink_status_t status;
while(SerialMAV.available())
uint8_t c= SerialMAV.read();
//Get new message
if(mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status))
//Handle new message from autopilot
switch(msg.msgid)
// case MAVLINK_MSG_ID_GPS_RAW_INT:
// mavlink_gps_raw_int_t packet;
// mavlink_msg_gps_raw_int_decode(&msg, &packet);
// Serial.print("\nGPS Fix: ");Serial.println(packet.fix_type);
// Serial.print("GPS Latitude: ");Serial.println(packet.lat);
// Serial.print("GPS Longitude: ");Serial.println(packet.lon);
// Serial.print("GPS Speed: ");Serial.println(packet.vel);
// Serial.print("Sats Visible: ");Serial.println(packet.satellites_visible);
case MAVLINK_MSG_ID_ESC_STATUS:
__mavlink_esc_status_t packet;
mavlink_msg_esc_status_decode(&msg, &packet);
for (int i=0; i<=4; i++){
Serial.print("\nCurrent Draw: ");
Serial.print(i);
Serial.println(packet.current[i]);
// case MAVLINK_MSG_ID_SERVO_OUTPUT_RAW:
// __mavlink_servo_output_raw_t packet;
// mavlink_msg_servo_output_raw_decode(&msg, &packet);
// Serial.print("Servo Output: ");
// Serial.print(packet.servo1_raw);
void request_datastream() {
//Request Data from Pixhawk
uint8_t _system_id = 255; // id of computer which is sending the command (ground control software has id of 255)
uint8_t _component_id = 2; // seems like it can be any # except the number of what Pixhawk sys_id is
uint8_t _target_system = 1; // Id # of Pixhawk (should be 1)
uint8_t _target_component = 0; // Target component, 0 = all (seems to work with 0 or 1
uint8_t _req_stream_id = MAV_DATA_STREAM_ALL;
uint16_t _req_message_rate = 0x01; //number of times per second to request the data in hex
uint8_t _start_stop = 1; //1 = start, 0 = stop
// STREAMS that can be requested
* Definitions are in common.h: enum MAV_DATA_STREAM and more importantly at:
https://mavlink.io/en/messages/common.html#MAV_DATA_STREAM
* MAV_DATA_STREAM_ALL=0, // Enable all data streams
* MAV_DATA_STREAM_RAW_SENSORS=1, /* Enable IMU_RAW, GPS_RAW, GPS_STATUS packets.
* MAV_DATA_STREAM_EXTENDED_STATUS=2, /* Enable GPS_STATUS, CONTROL_STATUS, AUX_STATUS
* MAV_DATA_STREAM_RC_CHANNELS=3, /* Enable RC_CHANNELS_SCALED, RC_CHANNELS_RAW, SERVO_OUTPUT_RAW
* MAV_DATA_STREAM_RAW_CONTROLLER=4, /* Enable ATTITUDE_CONTROLLER_OUTPUT, POSITION_CONTROLLER_OUTPUT, NAV_CONTROLLER_OUTPUT.
* MAV_DATA_STREAM_POSITION=6, /* Enable LOCAL_POSITION, GLOBAL_POSITION/GLOBAL_POSITION_INT messages.
* MAV_DATA_STREAM_EXTRA1=10, /* Dependent on the autopilot
* MAV_DATA_STREAM_EXTRA2=11, /* Dependent on the autopilot
* MAV_DATA_STREAM_EXTRA3=12, /* Dependent on the autopilot
* MAV_DATA_STREAM_ENUM_END=13,
* Data in PixHawk available in:
* - Battery, amperage and voltage (SYS_STATUS) in MAV_DATA_STREAM_EXTENDED_STATUS
* - Gyro info (IMU_SCALED) in MAV_DATA_STREAM_EXTRA1
// Initialize the required buffers
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
// Pack the message
mavlink_msg_request_data_stream_pack(_system_id, _component_id, &msg, _target_system, _target_component, _req_stream_id, _req_message_rate, _start_stop);
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg); // Send the message (.write sends as bytes)
SerialMAV.write(buf, len); //Write data to serial port
