I am looking to use 8 x relays from my arduino and have 8 x 2n3904 transistors to trigger them, the transistors are similar to 2n2222 which have a peak 200ma base current,
is this dangerous? i hear 500ma is the max before a fuse blows in the usb. the relays may be turned on at the same time and I also need individual control.
While I'm definitely no expert here, you should probably be careful. While the USB can handle a maximum of 500 milliamps, each pin on the board has a maximum of only 40 milliamps! You should still be able to use the transistors, but you need to wire in appropriate resistors between the base and the output pins, to limit the current going trough the pins. If the 40 milliamp max you can pull out of the pins isn't enough for you, it is my understanding that you can use a so-called darlington transistor array, which is basically another transistor amplifying the weak output from the pin to your desired 200mA base current for the transistors driving the relays. Hope this helps
You should be using a current-limiting resistor in the base connections.
The AVR outputs can deliver a max. current of 40 mA each, with a total current of 200 mA (IIRC). I'd aim for no more than 10 mA on each one.
The current available from the USB supply is negotiated in the software, 500 mA is the default value, and that is probably what is available to the Arduino. You need to calculate the total current consumption of your circuit, and use an external supply if it is excessive.
No they don't. It might be the peak collector current. Anyway that is not the issue you need to know how much current your relay takes. That is what actually flows. The transistor ratings are only how much then can take not what they will take. What they do take is determined by your relay and your base resistor.
No this is the maximum value that can be supplied. No negotiations is going to be over that. Actually the default value is 100mA but the requested value is read from the EPROM inside the USB / Serial chip.
Only if you are lucky, some machines blow up the USB interface. (and it's not a fuse anyway it is a crowbar circuit)
but the power for the relays is coming from an external PSU connected to 5v regulator! the psu can handle over 1amp. the usb only powers the arduino and the current draw from the base of the transistors, surly.
the whole point of the 9x transistors is to use an external psu to power the relays. right? or am i wrong here?
