Hey gang, took a couple of nights, finally got MAX6953 working to drive four 5x7 led matrix displays. My application is to read the time coming out of a fencing scoring machine and to display it in big digits. (Previously remote displayed the 6 score lights just using individual pins to turn on discrete transistors for banks of LEDs).
Was having trouble getting the digits to be as bright as during the display test (all LEDs on at half power), finally realized need two nibbles of info in two locations to control 4 digits.
The 6953 supports 2 registers per digit (Plane0 & Plane1) and allows one blink back & forth between them. I am not doing that, I only write to Plane0 and don't do any blinking.
To breadboard, needed 3 strips of protoboards with 5x7s mounted 2 above the 6953 and two below. The 5x7s span the full width of the 3 strips, so all the interconnections were done at the sides of the 40-pin dip in the middle of the board. MAX6953 & Displays are wired per MAX6953 datasheet. 5V Power is from Duemilanove. Colon is 2 LEDs in series with 390R from +5V to D3.
Have 4.7K pullups on SCD, SDA, Blink.
Have 22K for Rset & some small cap for Osc-set, not sure of value but the display is rock solid, can't see any flickering.
Goal for this program - grab serial xmissions from PC's USB port, send out the time parts to MAX6953 for display on four LITEON LTP-2057 5x7 displays.
Looking for these bytes
- Byte with MSBs = 0000
- Byte with MSBs = 0001
- Byte with MSBs = 0010
- Byte with MSBs = 0011
Using IIC (I2C) for interfacing to MAX6953
- Arduino analog 5 - I2C SCL, pin 24
- Arduino analog 4 - I2C SDA, pin 23
#include <Wire.h> // bring in Wire Library
// I2C device address is 1 0 1 A3 A2 A1 A0 with AD1, AD0 both low so looking for A3-2-1-0 to be all low also.
#define COMMAND_ADDRESS 0x50 // (B1010000), 7 bits
#define CONFIG_ADDRESS 0x04
#define INTENSITY10_ADDRESS 0x01
#define INTENSITY32_ADDRESS 0x02
#define SCANLIMIT_ADDRESS 0x03
#define DIGIT0_ADDRESS 0x20 // write Plane 0
#define DIGIT1_ADDRESS 0x21 // write Plane 0
#define DIGIT2_ADDRESS 0x22 // write Plane 0
#define DIGIT3_ADDRESS 0x23 // write Plane 0
// just realized I never defined the Display Test as 0x07, just put it in.
unsigned int val = 0; // variable to store the 5 bytes that come in, a byte every 5 ms (200 Hz rate)
int maskupperbyte = 0;
int masklowerbyte = 0;
int Minutes_Tens;
int Colon;
int Minutes_Ones;
int Seconds_Tens;
int Seconds_Ones;
int numberToDisplay;
int ColonLED=3;
// no need to define pinMode for A4, A5, set up by library
pinMode(ColonLED, OUTPUT);
// start up I2C, uses Analog 5 for Clock, Analog 4 for data
Wire.begin(); // nothing in () because we are the master
// write config register
Wire.beginTransmission(COMMAND_ADDRESS);
Wire.send(CONFIG_ADDRESS);
Wire.send(0x05);
// 0000 0001 => 0 shutdown, 1 = normal mode, no fooling with blink modes & stuff
// 0000 0010 = not used
// 0000 0100 => 0 slow blink, 1 = fast blink
// 0000 1000 => 0 = global blink disabled (Plane 1 data ignored), 1 global blink enabled Plane 1 data used)
// 0001 0000 => 0 = blink unaffected during I2C acknowledge
// 0010 0000 => 0 = data unaffected during I2C ack, 1 = data cleared
// 0100 0000 => not used
// 1000 0000 => blank phase - blink status is read back
// for this use: 0000 0101 => normal operation, fast blink
Wire.endTransmission();
// write intensity10 register
Wire.send(INTENSITY10_ADDRESS);
Wire.send(0xEE); // E = 15/16 (max), 1 nibble each for digit 0 & 2
// write intensity32 register
Wire.send(INTENSITY32_ADDRESS);
Wire.send(0xEE); // E = 15/16 (max), 1 nibble each for digit 1 & 3
// write scanlimit register
Wire.send(SCANLIMIT_ADDRESS);
Wire.send(0x01); // 01 = 4 display digits
//display test
Wire.send(0x07);
Wire.send(0x01); // 01 = display test on
delay (1500); // for # of milliseconds
Wire.send(0x07);
Wire.send(0x00); // 00 = normal operatiom
Wire.endTransmission(); // does not change loaded data tho
Serial.begin(4800); // open the serial port
// Need 4800 for Firefly operation.
// PC COMx uses 57600 for downloading via USB.
Serial.flush();
} // end of void setup
// read the incoming byte:
val = Serial.read();
// search for a message -interestingly, will not work correctly using Arduino -0019
// serial monitor function to send bytes out - need to use program like RS232 Monitor,
// better simulates the actual device that will be sending us data.
// Wonder if due to val being declared as unsigned int?
maskupperbyte = val & 0xF0; // looking for 1xxx and 0000-0011 in real application.
masklowerbyte = val & 0x0F; // looking for 0000-1010 in real application
// MSB=0+000 -> data has weapon 00-01-10, Colon bit, Ten-Minute bit
if (maskupperbyte == 0x00)
// lowerbyte bit 0 = tens of minutes, only 0 or 1
// lowerbyte bit 1 = colon, 1 = on, 0 = off
// other bits are don't cares
// if LSB is high, display a 1, otherwise blank it, font is per table 15
// write 0x20 (blank) or 0x31 (1) depending on Tens bit
int Minutes_Tens = val & 0x01;
if (Minutes_Tens == 0)
numberToDisplay = 0x20;
numberToDisplay = 0x31;
// sequence needed is Command, Data Pointer, Data
// write digit0 register
Wire.send(DIGIT0_ADDRESS);
Wire.send(numberToDisplay);
Colon = masklowerbyte & 0x02; // see if colon is on or off
if (Colon == 0x02)
{digitalWrite(ColonLED,LOW);} // pulling cathode of LED low to turn it on.
{digitalWrite(ColonLED,HIGH);}
} // end of maskupperbyte == 00
// MSB=0+001 -> data = single minutes, 0-A, A is command to blank the digit, B-F will not be sent
if (maskupperbyte == 0x10)
if (masklowerbyte == 0x0A)
// write 0x20 for blank
Minutes_Ones = masklowerbyte;
numberToDisplay = 0x30|Minutes_Ones; // add 0011 for upper nibble per Table 15
// write digit1 register
Wire.send(DIGIT1_ADDRESS);
} // end of maskupperbyte = 10
// MSB=0+010 -> data = Ten-Seconds, 0-A, A is command to blank the digit, B-F will not be sent
if (maskupperbyte == 0x20){
if (masklowerbyte == 0x0A){ // write 0x20 for blank
else {
Seconds_Tens = masklowerbyte;
numberToDisplay = 0x30|Seconds_Tens;
// write digit2 register
Wire.send(DIGIT2_ADDRESS);
Wire.send(numberToDisplay); //
} // end of maskupperbyte == 20
// MSB=0+011 -> data = single seconds, 0-A, A is command to blank the digit, B-F will not be sent
if (maskupperbyte == 0x30){
else {
Seconds_Ones = masklowerbyte;
numberToDisplay = 0x30|Seconds_Ones;
// write digit3 register
Wire.send(DIGIT3_ADDRESS);
} // end of maskupperbyte == 30
// for testing, I commented out the serial read, and incremented val here by 0x11 to give the displays something to show, with a slight delay. makes for odd looking results, but just wanted to see that it worked.
} // end if available
} // end void
