MAX7219 + LED Matrix Wiring?
marco_c:
Are you sure that you are mapping the DP (decimal point) output signal from the IC to the right column or row?
I think Marco nailed it there.
Look at the sequence the above page from the data sheet: left-to-right it's DP, A, B, C, D, E, F, G
Not: A, B, C, D, E, F, G, DP, as I think you numbered them.
row     led pin     chip pin
1         9         14 SEG A
2        14         16 SEG B
3         8         20 SEGC
4        12         23 SEG D
5         1         21 SEG E
6         7         15 SEG F
7         2         17 SEG G
8         5         22 SEG DP
PaulRB:
No, I'm not sure - I just tried to use the LedControl library. Guess the mapping is done inside the library? So if the mapping is incorrect it must be in the library?
And I was following the pin connection table given in this thread some time ago. Is that table correct?
No, it's done inside the chip. The library is not re-mapping anything.
So try this:
1         9         22 SEG DP
2        14         14 SEG A
3         8         16 SEG B
4        12         20 SEG C
5         1         23 SEG D
6         7         21 SEG E
7         2         15 SEG F
8         5         17 SEG G
Genesis92:
row display pin MAX7219 pin
1 9 14
2 14 16
3 8 20
4 12 23
5 1 21
6 7 15
7 2 17
8 5 22
Yes, that might be wrong. Try my suggestion and we'll know for sure.
I'm about to do that because I realized that the table given in reply #1 is wrong. The one above is probably correct (just wrote down the new sequence before reading your reply).
Guess the lesson learned this time is - not trust everything you read on Internet (surprised?? ;))
PaulRB:
The first table was incorrect and your suggestion was correct. Thanks :slight_smile:
Wonder why the first able has not been questioned?
thehardwareman:
Thanks for feeding back. +1 Karma
thehardwareman:
It was a pretty subtle error for anyone to have spotted in that long and detailed reply. But I would expect someone to have tried it and found the error over the last 6 years!
