Hello all! Longtime Arduino hobbyist, new poster to the forum. I have a Mega sitting on my desk in front of me and 32 small rocker switches. I am using the internal pull-up resistor to have all these switches on the single Arduino Mega.
This method works so far for one switch. Does anyone know if I will damage my board by connecting them all at once to the main GND pin and then routing each input to a different Digital pin?
I would just like to clarify that rather than simply reading the state and assigning that value as output, to read the value and ONLY change the output when it's a LOW value?
//switches are checked every 100ms
void checkSwitches()
byte currentState;
//*********************************************** m a s t e r P i n
//masterPin switch
currentState = digitalRead(masterPin);
if (lastMasterState != currentState)
//update to the new state
lastMasterState = currentState;
//is the switch pushed ?
if (currentState == PUSHED)
//do something
} //END of this switch
//other switches
} //END of checkSwithes()
anti-bouncing "of the poor" is to add some software delay after detecting a state change. 15ms usually works fine with most switches I played with.
But don't write a delay right away - it depends how long the action you trigger with the switch takes. if it's long enough until you come back reading the switch then no delay is needed
you can of course record the time of the change and take that into account to decide if you are bouncing or not. depends if you can afford to block the rest of the code for some ms (which is long in microcontroller's time)
@groundFungus Do you mean alter the hardware the Arduino is connected to? I'd rather go from Mega to Teensy or Leo Bodnar in this case.
@LarryD That code is pretty much the structure I was thinking. How does it differ from the standard code design?
@J-M-L So make the delay longer than a typical bounce, like a filter? That's totally fine as I only need to read the 32 switches once every one or two seconds.
Well, that’s the standard code design I always use.
Edit
You do need this in loop( )
//*********************************************** check switches T I M E R
//is it time to check the switches ?
if (millis() - switchMillis >= 100)
//restart the TIMER
switchMillis = millis();
checkSwitches();
I would put it differently. It depends on whether the rest of the code can tolerate not getting the switch event. Timing out a debounce period does not require blocking the rest of the code.
With switches that are wired correctly and aren't picking up any spurious readings, you won't read a LOW from a switch that wasn't on its way to fully closed, nor HIGH from switch that wasn't on its way to fully open. So you can react virtually instantly to switch events. Important for percussionists, not so much for receptionists.
Looking at the switches frequently and regularly is the way to go as at least one solution above covers. 100 ms will seem sluggish to many. I do have switches where such an eternity woukd be needed, spent too little on some arcade-style pushbutton switches. Try not looking again for 20 ms, that shoukd be plenty.
Not sluggish - unresponsive to another press come too soon.
Yes, I will not delay after every single rocker- instead, delay after all have been checked once per cycle.
Looks like that code double-checks the state of the rocker after a short delay, thereby allowing the code to speed up instead of having a constant delay every cycle?
I will be very honest @alto777 ... I'm not sure what you mean by the second and third paragraphs. Do, in layman's, you mean bouncing is not much of an issue anyway if you scan regularly?
These buttons will initiate a change in a simulated aircraft's state, for instance, landing gear coming down. That takes a full second to register in real life anyway. I'm not too worried about speed.
If you control looking at the switches as @LarryD outlines in #13 above, where there is no use of the delay() function, you will get the fastest response to switch events.
If you do as @J-M-L proposes and takes the trouble to demonstrate (THX!), you are always adding 15 ms to the possibility of reacting to an event, and you are stalling the processing for the same period.
As you say, it may not matter. I'm in the end of things where paying attention to odd milliseconds here and there is of value. There is no need for delay(), certainly not in switch debouncing nor its old brother general signal conditioning, where you may have more things going on than contact bounce.
@groundFungus can be depended on to suggest using hardware. I agree and never do, not even when I am in a hurry and just need a damn switch.
Speaking of hardware, something I can be depended on to suggest is using real pull-up resistors of a substantial lower value, like 10K. Just call me old; there was a time when it was always important, instead of just sometimes these days.
