MCP23xxx hardware address pins internal resistors
I'd like to know whether the hardware address pins on MCP23008, MCP23017, MCP23S08 and MCP23S17 are pulled up to VDD, pulled down to VSS or left floating. I want to use a SPST DIP switch to control the hardware address. Should I use external pull-up resistors?
Thanks in advance,
anustart
What's their spec say? Probably that input pins should not be left floating. I'd go with pullups, and switch to Gnd when low is desired. No switching 3.3V or 5V on & off to pins.
Up to 0.5mA from a 10K to +5V is likely sufficient for a CMOS input. Since it's static input, can be even less - 20K, 25K.
