I've been having some bad luck when it comes to these CAN devices.
I tried seeed studio's CANbus shield v1.0, and tried my own boards.
The trouble I'm having is Error sending message on my own boards, and Error entering configuration mode on the seeed shield.
Does anyone have any pointers on rookie mistakes?
Serial monitor my board:
Entering Configuration Mode Successful!
Setting Baudrate Successful!
MCP2515 Initialized Successfully!
Error Sending Message...
Serial monitor SeeedStudio's CANshield:
Entering Configuration Mode Failure...
Error Initializing MCP2515...
Message Sent Successfully!
// CAN Send Example
#include <mcp_can.h>
#include <SPI.h>
MCP_CAN CAN0(10);Â Â // Set CS to pin 10
 // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
 if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
 else Serial.println("Error Initializing MCP2515...");
 CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
byte data[8] = {0x05, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
 // send data: ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
 byte sndStat = CAN0.sendMsgBuf(0x100, 0, 8, data);
 if(sndStat == CAN_OK){
  Serial.println("Message Sent Successfully!");
  Serial.println("Error Sending Message...");
 delay(100); // send data per 100ms
