MCP4561 singlePotExample.ino Wire.h to the rescue.
Exhausted but not defeated (completely).
I never could get this Example for use with the MCP4561 library. After a couple days trying to get the digital pot to work and failing to do so, I switched gears to simple Wire.h library commands for the I2C bus. The pot now works great. I'm sure that the Example sketch with the library works but it's beyond me as to what's wrong with it. In any case, the Wire.h library is sufficient for getting the job done to adjust the pot's wipers.
// BUT BUT BUT... THIS DOESN'T CONTROL THE 4561 FOR SOME REASON... INVESTIGATE/ AND / UPDATE THIS NOTE.
  This is an example for the Microchip MCP4561 8 bit digital pot
  These displays use I2C/TWI to communicate,
  2 pins are required to interface
  Written by Daniel de kock
  BSD license, all text above must be included in any redistribution
// Functions and returns
#include <MCP4561.h>
#include <Wire.h>
MCP4561  digiPot(46);                                            //declare an instance of MAX4561 with Device addr 46 ( 0101 110 ), ie A0 pin pulled low
 Wire.begin();                                                   // begin IIC communication
 unsigned int read(char mem_addr);				 // mem addr 0x00 - 0x0f ( 0-16 ), returns 9 bit value at that adress ( 0- 257 )
 int write(char mem_addr,int setValue);                          // mem_addr is 00-0F, setvalue is 0-257 returns 1 if succesful and 0 otherwise, tthis will set the volatile and nonvolatile values
 int openCircuit();                                              // creates and open circuit where the pot is ( disconnects the internals) , returns 1 if sucess, 0 otherwise
 int enableOutput();                                             // enables the pot output after an open circuit, returns 1 if sucess, 0 otherwise
// MEMORY adresses
 ADDR    |FUNCTION    |CMDs
 00      |VOLATILE WP 0        |R,W,Inc,Decr      Wiper 0 value
 01      |VOLATILE WP 1        |R,W,Inc,Decr      ** Wiper 1 value dual output version only
 02      |NonVOLATILE WP 0     |R,W,HVInc,HVDecr  Wiper 0 value
 03      |NonVOLATILE WP 1     |R,W,HVInc,HVDecr  ** Wiper 1 value dual output version only
 04      |VOLATILE TCON        |R,W
 05      |STATUS               |R
 06 - 0E |EEPROM               |R,W
 0F      |EEPROM               |R,W,HV_WPD,HV_RPD
 R     :  Read-able
 W     :  Write-able
 Inc   : increment value ( check datasheet for data value to be sent to pot to use this function)
 Decr  : Decrement value ( check datasheet for data value to be sent to pot to use this function)
// External includes
#include <Wire.h>
MCP4561 digiPot(46);                              //declare an instance of MAX4561 with Device addr 46 ( 0101 110 ), ie, A0 pin lulled low
// Setup loop
  Wire.begin();                                   // join i2c bus as master
  Serial.begin(9600);                            // used for serial control
  displayMenu();                                  // display a UI on serial
// Main loop
  int c;
  if (Serial.available() > 0)
    c= Serial.read();
   int success=0;
  delay(5);
  switch(c)
  case 'r':
    char addr;
    unsigned int readValue;
    addr = Serial.parseInt();
    readValue = digiPot.read(addr);                 // this is the example method, all the rest is formatting, it will return the unsigned value of the requested memory adress, 4096 if the memory does not exist
    Serial.print(" MCP4561 memory at 0x0");
    Serial.print(addr,HEX);
    Serial.print(" : ");
    Serial.println(readValue);
    Serial.flush();
  case 's':
  int setOutput;
  setOutput = Serial.parseInt();
  int success;
  success=0;
  success = digiPot.write(char 00,setOutput);             // this is the example method, all the rest is formatting, this method will return 1 if the write was succesful, 0 otherwise
  success = digiPot.write(char 02,setOutput);
    Serial.println(success);
    if (success)
     Serial.print(" MCP4561 set to : ");
     Serial.println(setOutput);
   else{Serial.println(" MCP4561 setting unsuccesful ");}
    Serial.flush();
  case 'm':
    success=0;
    displayMenu();
    Serial.flush();
    case 'd':
    success = digiPot.openCircuit();
    if (success)
     Serial.println(" MCP4561 output open circuit");
    case 'e':
    success=0;
    success = digiPot.enableOutput();
    if (success)
     int output;
     output = digiPot.read(0);
     Serial.print(" MCP4561 output to  : ");
     Serial.println(output);
// Serial menu display function
void displayMenu()
  Serial.println( "Microchip MCP4561 library example");
  Serial.println( "m     : Menu");
  Serial.println( "rxx   : read memory at xx ( 0-16 )");
  Serial.println( "sXXX  : set output 0 to 0-257");
  Serial.println( "d     : open circuit output");
  Serial.println( "e     : enable output");
  Serial.println( "----------------------------------");
UPDATE:
Problem solved finally. I just aborted my effort to trouble shoot the code (and MCP4561 library) that I posted above. Instead, I went back to basics with simple I2C control just using Wire.h functionality. The pot works great.
Case closed. Solution inspired by the following people with my sincere thanks.
// I2C Digital Potentiometer
// by Nicholas Zambetti http://www.zambetti.com
// and Shawn Bonkowski http://people.interaction-ivrea.it/s.bonkowski/
// Demonstrates use of the Wire library
// Controls AD5171 digital potentiometer via I2C/TWI
// Created 31 March 2006
// This example code is in the public domain.
Hi and thanks for posting the update.
Would you be able to share your code? I just got the MCP4562 and trying to figure out their (somewhat complex) I2C.
Thanks!
