Mcufriend_kbv touchscreen example not compiling
Hello, I'm getting started with the lcd tft 3.5" touchscreen and after searching it appeared to me that the adafruit library doesn't support 3.5" lcd screens.
But the mcufriend_kbv does which is great but now when I try to run one of the touchscreen examples (touch_shield_new) as it is I get this error:
Using board 'uno' from platform in folder: C:\Users\Youssef\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\Youssef\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "C:\\Users\\Youssef\\AppData\\Local\\Temp\\arduino-sketch-0F29558DB335B7B50B4423C32AADE3C5\\sketch\\Touch_shield_new.ino.cpp" -o nul
Alternatives for MCUFRIEND_kbv.h: [MCUFRIEND_kbv@3.0.0-Release]
ResolveLibrary(MCUFRIEND_kbv.h)
  -> candidates: [MCUFRIEND_kbv@3.0.0-Release]
"C:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\MCUFRIEND_kbv" "C:\\Users\\Youssef\\AppData\\Local\\Temp\\arduino-sketch-0F29558DB335B7B50B4423C32AADE3C5\\sketch\\Touch_shield_new.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.11.5]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.11.5]
"C:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\MCUFRIEND_kbv" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\Youssef\\AppData\\Local\\Temp\\arduino-sketch-0F29558DB335B7B50B4423C32AADE3C5\\sketch\\Touch_shield_new.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.14.1]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.14.1]
"C:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\MCUFRIEND_kbv" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Youssef\\AppData\\Local\\Temp\\arduino-sketch-0F29558DB335B7B50B4423C32AADE3C5\\sketch\\Touch_shield_new.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\MCUFRIEND_kbv" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\Wire\\src" "C:\\Users\\Youssef\\AppData\\Local\\Temp\\arduino-sketch-0F29558DB335B7B50B4423C32AADE3C5\\sketch\\Touch_shield_new.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\MCUFRIEND_kbv" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Youssef\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\Wire\\src" "-IC:\\Users\\Youssef\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "C:\\Users\\Youssef\\AppData\\Local\\Temp\\arduino-sketch-0F29558DB335B7B50B4423C32AADE3C5\\sketch\\Touch_shield_new.ino.cpp" -o nul
Alternatives for TouchScreen.h: []
ResolveLibrary(TouchScreen.h)
  -> candidates: []
Using library MCUFRIEND_kbv at version 3.0.0-Release in folder: C:\Users\Youssef\Documents\Arduino\libraries\MCUFRIEND_kbv
Using library Adafruit_GFX_Library at version 1.11.5 in folder: C:\Users\Youssef\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.14.1 in folder: C:\Users\Youssef\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\Youssef\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\Youssef\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\SPI
Compilation error: Error: 13 INTERNAL: exit status 1
So what seems to be the problem please
Yeah this was actually the problem, the file mentioned is not even in the files of the github repository thanks.
