my project is measure heart rate and O2 saturation by using MAX 30100 , body temperature by MAAX30205 and body motion by using GY521 . All sensors are connected to same i2C bus. When I upload the code for individual sensor it work fine but when I upload the code that join them together MAX30100 turn on but it give me Zero reading the code below for MAX30100 alone and the results
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS 1000
// Create a PulseOximeter object
PulseOximeter pox;
// Time at which the last beat occurred
uint32_t tsLastReport = 0;
// Callback routine is executed when a pulse is detected
void onBeatDetected() {
Serial.println("Beat!");
Serial.print("Initializing pulse oximeter..");
// Initialize sensor
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
// Configure sensor to use 7.6mA for LED drive
pox.setIRLedCurrent(MAX30100_LED_CURR_27_1MA);
// Register a callback routine
pox.setOnBeatDetectedCallback(onBeatDetected);
// Read from the sensor
pox.update();
// Grab the updated heart rate and SpO2 levels
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
Serial.print("Heart rate:");
Serial.print(pox.getHeartRate());
Serial.print("bpm / SpO2:");
Serial.print(pox.getSpO2());
Serial.println("%");
tsLastReport = millis();
And the bellow code for all sensors
#include<Wire.h>
#include "Protocentral_MAX30205.h"
MAX30205 tempSensor;
const int MPU=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
PulseOximeter pox;
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
tempSensor.begin();
// set mode control register to active mod
if (!pox.begin()) {
for(;;);
while(!tempSensor.scanAvailableSensors()){
Serial.println("Couldn't find the temperature sensor, please connect the sensor." );
delay(5000);// put your setup code here, to run once:
pox.update();
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU,12,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
GyX=Wire.read()<<8|Wire.read();
GyY=Wire.read()<<8|Wire.read();
GyZ=Wire.read()<<8|Wire.read();
Serial.print("Accelerometer: ");
Serial.print("X = "); Serial.print(AcX);
Serial.print(" | Y = "); Serial.print(AcY);
Serial.print(" | Z = "); Serial.println(AcZ);
Serial.print("Gyroscope: ");
Serial.print("X = "); Serial.print(GyX);
Serial.print(" | Y = "); Serial.print(GyY);
Serial.print(" | Z = "); Serial.println(GyZ);
Serial.println(" ");
float temp = tempSensor.getTemperature(); // read temperature for every 100ms
Serial.print(temp ,2);
Serial.println("'c" );
delay(100);// put your main code here, to run repeatedly:
I am new on coding if you can help me solve this issue
