Measuring capacitance on arduino due
hello, I want to get capacitance value using the code below.
but I have to use arduino due, and I don't know arduino due's stray capacitance.
what is arduino due's stray capacitance value???
I already set analogReadResolution to 12.
thanks.
const int OUT_PIN = A2;
const int IN_PIN = A0;
//Capacitance between IN_PIN and Ground
//Stray capacitance is always present. Extra capacitance can be added to
//allow higher capacitance to be measured.
const float IN_STRAY_CAP_TO_GND = 24.48; //initially this was 30.00
const float IN_EXTRA_CAP_TO_GND = 0.0;
const float IN_CAP_TO_GND  = IN_STRAY_CAP_TO_GND + IN_EXTRA_CAP_TO_GND;
const int MAX_ADC_VALUE = 4095;
  pinMode(OUT_PIN, OUTPUT);
  //digitalWrite(OUT_PIN, LOW);  //This is the default state for outputs
  pinMode(IN_PIN, OUTPUT);
  //digitalWrite(IN_PIN, LOW);
  //Capacitor under test between OUT_PIN and IN_PIN
  //Rising high edge on OUT_PIN
  pinMode(IN_PIN, INPUT);
  digitalWrite(OUT_PIN, HIGH);
  analogReadResolution(12);
  int val = analogRead(IN_PIN);
  //Clear everything for next measurement
  //Calculate and print result
  float capacitance = (float)val * IN_CAP_TO_GND / (float)(MAX_ADC_VALUE - val);
  Serial.print(F("Capacitance Value = "));
  Serial.print(capacitance, 3);
  Serial.print(F(" pF ("));
  Serial.print(val);
  Serial.println(F(") "));
  while (millis() % 500 != 0)
You have to measure the entire stray capacitance of your setup.
Does the Due have Schmitt Trigger inputs as required for this project?
Yes it does
