Hey everyone. I'm currently building a relatively simple playback device with an arduino and processing. I have the arduino hooked to a rotary encoder which is hooked to a hand crank. You turn the crank and then the encoder records the movement and sends it to processing and then it loops through a series of images, forwards or backwards. At the moment, it more or less works.
Problems I'm having at the moment:
*I think its too fast. If I turn the crank very slowly then the images tick one by one, which is nice. But If I turn the crank at a comfortable rate, and then stop. Then the program continues to cycle through several more images. My guess that this lag is because even just a single turn of the crank cycles through the encoder several times and the program is just struggling to catch up. Is there a way to slow this thing down? So that a turn of the hand crank doesnt cycle through the image sequence so fast? Either by changing the arduino code or the processing code?
*Also, is there a way to progressively rotate the images each time they appear? Like say, image appears with 0 rotation, next with 12 degree rotation, next with 24 degree rotation, etc. The image sequence is actually a wheel so I want to spin it a little bit as it cycles through the animations.
Thanks a bunch guys: here's my code and a link to my encoder for reference:
Arduino code:
#include <QuadEncoder.h>
byte qe1Move=0;
QuadEncoder qe(8,9);
byte count = 0;
qe1Move=qe.hb();
if (qe1Move=='>')
count = count + 1;
Serial.write(count);
if (count>46)
count = 0;
if (qe1Move=='<')
count = count - 1;
if (count<2)
count = 48;
//Serial.print(char(qe1Move));
//else if (qe1Move=='<')
//delay(100);
Processing code:
import fullscreen.*; //Imports the Fullscreen library
import processing.serial.*;
Serial myPort; // The serial port
FullScreen fs; //Creates an object called fs from the FullScreen class
int numFrames = 48; //Total number of frames including the 0
int frame = 0;//Declares frame number
int val; // Data received from the serial port
PImage[] images;//Creates and object called images from PImage class
images = new PImage[numFrames];//Assignes and array to the images object that will hold 48 images
size(1280, 720);
frameRate(24);
for ( int i = 0; i<numFrames; i++ )//A loop increments from 0 to 47
images[i] = loadImage("FriendlyFire_"+ i + ".png");//Assignes and exaxt name to each member of the array
//Note that this loop is an setup which means it will run only once when the program starts.
fs = new FullScreen(this); //Declares the fs object as new fullscreen
fs.enter(); //runs the fullscreen
String portName = Serial.list()[0];
myPort = new Serial(this, Serial.list()[0], 9600);
void draw()
background(0);
frame = ((frame+1) % numFrames);//Frame number increments until 48
image(images[frame], 0, 0);//Displays the image
if ( myPort.available() > 0) { // If data is available,
val = myPort.read(); // read it and store it in val
frame = val;
Encoder:
http://www.sgbotic.com/index.php?dispatch=products.view&product_id=1093
Thanks a bunch guys. I'm new to this and to coding in general so I apologize ahead of time if I'm slow or confused with your responses.
I'm very appreciative, I really gotta try to get this thing working by the end of the weekend. Thanks again!
