Mega 2560 Ports
I used a Nano classic because it exposed A0-A7, of which I used A0-A6 to write 7 bits to the port simultaneously. Some of you might already see the issue. A6 and A7 do not work as digital outputs with the 328P. So far as I see there is no way to write 7 or 8 bits to a single port as a digital output on any port on the 328P.
To that end, I upgraded the project to a Mega 2560. Looking at the pin/port diagram for the Mega 2650, it looks like I can easily use Port F or Port K to write 7 or 8 bits as a digital output. Do I have that correct or is there a pitfall that I've missed?
There are several more ports on the header at the bottom that are not listed in your diagram.
Here is a list I got from the pins_arduino.h file, sorted by port. All eight pins are available on ports A, B, C, F, K, and L.
//Port ** Arduino Pin Number ** pin designation
PA 0 ** 22 ** D22
PA 1 ** 23 ** D23
PA 2 ** 24 ** D24
PA 3 ** 25 ** D25
PA 4 ** 26 ** D26
PA 5 ** 27 ** D27
PA 6 ** 28 ** D28
PA 7 ** 29 ** D29
PB 0 ** 53 ** SPI_SS
PB 1 ** 52 ** SPI_SCK
PB 2 ** 51 ** SPI_MOSI
PB 3 ** 50 ** SPI_MISO
PB 4 ** 10 ** PWM10
PB 5 ** 11 ** PWM11
PB 6 ** 12 ** PWM12
PB 7 ** 13 ** PWM13
PC 0 ** 37 ** D37
PC 1 ** 36 ** D36
PC 2 ** 35 ** D35
PC 3 ** 34 ** D34
PC 4 ** 33 ** D33
PC 5 ** 32 ** D32
PC 6 ** 31 ** D31
PC 7 ** 30 ** D30
PD 0 ** 21 ** I2C_SCL
PD 1 ** 20 ** I2C_SDA
PD 2 ** 19 ** USART1_RX
PD 3 ** 18 ** USART1_TX
PD 7 ** 38 ** D38
PE 0 ** 0 ** USART0_RX
PE 1 ** 1 ** USART0_TX
PE 3 ** 5 ** PWM5
PE 4 ** 2 ** PWM2
PE 5 ** 3 ** PWM3
PF 0 ** 54 ** A0
PF 1 ** 55 ** A1
PF 2 ** 56 ** A2
PF 3 ** 57 ** A3
PF 4 ** 58 ** A4
PF 5 ** 59 ** A5
PF 6 ** 60 ** A6
PF 7 ** 61 ** A7
PG 0 ** 41 ** D41
PG 1 ** 40 ** D40
PG 2 ** 39 ** D39
PG 5 ** 4 ** PWM4
PH 0 ** 17 ** USART2_RX
PH 1 ** 16 ** USART2_TX
PH 3 ** 6 ** PWM6
PH 4 ** 7 ** PWM7
PH 5 ** 8 ** PWM8
PH 6 ** 9 ** PWM9
PJ 0 ** 15 ** USART3_RX
PJ 1 ** 14 ** USART3_TX
PK 0 ** 62 ** A8
PK 1 ** 63 ** A9
PK 2 ** 64 ** A10
PK 3 ** 65 ** A11
PK 4 ** 66 ** A12
PK 5 ** 67 ** A13
PK 6 ** 68 ** A14
PK 7 ** 69 ** A15
PL 0 ** 49 ** D49
PL 1 ** 48 ** D48
PL 2 ** 47 ** D47
PL 3 ** 46 ** D46
PL 4 ** 45 ** D45
PL 5 ** 44 ** D44
PL 6 ** 43 ** D43
PL 7 ** 42 ** D42
Works for me. Thanks for taking the time to answer.
Happy New Year!
