Mega working fine, Mega+Ethernet fail to upload ...
Hello! I need some help for my boards.
I just got my first arduino(mega) and start some projects.
The Mega working fine, i try the loop-back test and it works.
But after i connect the Ethernet shield, win7(64) give me error that cannot recognize the device and Fail to upload the code.
Some times it recognize it(i don't see warnings in Device Manager), but still fail to upload the code.
My Mega is cheap china version, chip(ATMEGA2560 16AU 1604)
Ethernet shield HanRun HR911105A
Here is the Error:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM13
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done.  Thank you.
I try new port and try to install the code to the Ethernet shield directly.
         Using Port                    : COM15
         Using Programmer              : arduino
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x76
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Can someone help me fix the upload.
Thanks!
having this same issue.... what could it be?
