I want to use Mega2560's analog comparator(two inputs--AIN0 & AIN1), Pin Mapped Table shows that AIN1 was mapped to Digital Pin 5(PWM), but AIN0 Do Not have a mapped pin,so how can i use AIN0? If anyone can give me some advise? Thanks for your help.
I have the same trouble, have you solve it?
I suspect the answer may lie in Section 25.1 of the Atmega 2560 datasheet
It is possible to select any of the ADC15:0 pins to replace the negative input to the Analog Com-
parator.
If that does not work the only solution I can see (from looking at my Mega) is to solder a wire the the AIN1 connector - not a job for someone with shaky hands.
...R
