Initiates a method inside the current state class (HTTPClientState::report_simulation_data)
The report_simulation_data method calls an external method (WifiComm::connect_wifi)
Processing stops outside the state class and the string is never printed till the end
INTRIGUING FACTS:
If I simply add more lines of Serial.println() right after that incomplete one, the code does not break in the same exact point, it will run a few more prints. Check it out:
Remember that unless you call flush() after your print, the printing happens slowly (even at 115200 bauds) compared to the speed of code execution and since the serial output is asynchronous, your main code continues.
Don’t trust where you see it stop printing to guess what was the last statement executed, your crash might be hundreds of lines further down in the code
The code has 7 states and each state has it’s own set of files. Once the bug occurs in many points of the code, there isn’t an specific code snippet for me to show yet. However, I can share the main file structure so you can understand the overall logic:
MAIN → Context → State → Specialized Module (such as ClientCommunication)
switch (context.stateFlow) {
case 0: // Self
context.change_state(selfDiagnosisStatePtr);
context.printFreeMemory("\[main::loop1\]");
context.run_health_check(); // !! stops printing
case 1: // Comm
context.change_state(communicationStatePtr);
context.report_signature_request();
context.session_new(); // !! stops printing
context.report_config(); // !! stops printing
context.report_health_check(); // !! stops printing
case 2: // Config update
cyclobot.change_state(configUpdateStatePtr);
cyclobot.update_config();
case 3: // Code update
cyclobot.change_state(codeUpdateStatePtr);
cyclobot.update_simulation_code();
case 4: // Comm
cyclobot.change_state(communicationStatePtr);
cyclobot.session_stop(); // !! stops printing
case 5: // Simulation
cyclobot.change_state(simulationStatePtr);
// cyclobot.run_simulation(); // !! stops printing
case 6: // Comm
cyclobot.report_simulation_data(); // !! stops printing
cyclobot.stateFlow++;
Thanks! I’ll read more about flush() but, even if it takes a little longer to print than the code to run, it shouldn’t stop printing, right?
By the way: I’m using F() inside all my Serial.prinln() calls. I suppose that is a best practice to optimize memory usage but I’m not sure if that might be causing any damage to the code… Please let me nkow if you have any other clue.
Ok, but where is the code printing those messages you have shown us? What the code does before and after those printouts?
Please post a complete code if you want us being able to help you.
Looking at the code you did not post I see problems in lines 4,21,24,43,36,57,59,78 in the third include for starters. You also have the blue and purple wires swapped. This is what my crystal ball shows. Without the code and annotated schematic I say good by and good luck.
I had to make sure that flush() wasn't enought to solve my problem and, then, isolate one of the bug’s traceback snippets into a propper branch. The following link points to a simplified version of the code that, besides exposing the firmware's base design, it also leads us straight to one of the breaking points where Serial.println() stops.
Besides the link, in the following lines we have the central snippets related to the bug, from main.cpp, Context.cpp and HTTPClientState.cpp (where the bug happens):
src/main.cpp :
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <WiFiEsp.h>
#include "../include/core_states/BaseState.h"
#include "../include/core_states/self/IdleState.h"
#include "../include/core_states/comm/HTTPClientState.h"
#include "../include/Context.h"
// Set state classes
BaseState *communicationStatePtr = new HTTPClientState();
BaseState *idleStatePtr = new IdleState();
// Create state machine
FiniteStateMachine fsm_context(idleStatePtr);
// Extra serial port for wifi
SoftwareSerial esp8266(fsm_context.paramPtr->peripheralMappingPtr->wifiEspRX,
fsm_context.paramPtr->peripheralMappingPtr->wifiEspTX); // software-based serial port to communicate with wifi module
Serial.begin(9600); // Enable communication over the USB serial port console 9600 Bps
fsm_context.printFreeMemory("[main::setup]");
Serial.println(F("[main::setup] starting clock (rtc)"));
fsm_context.rtc.begin();
fsm_context.now = fsm_context.rtc.now();
Serial.print(F("[main::setup] date: "));
Serial.print(fsm_context.now.day());
Serial.print(F("/"));
Serial.print(fsm_context.now.month());
Serial.println(fsm_context.now.year());
Serial.print(F("[main::setup] time: "));
Serial.print(fsm_context.now.hour());
Serial.print(F(":"));
Serial.print(fsm_context.now.minute());
Serial.println(fsm_context.now.second());
// Serial.println(F("[main::setup] initializing WiFi module"));
// WiFi.init(&esp8266);
Serial.print(F(" ************************ ************[main::loop"));
Serial.print(fsm_context.stateFlow);
Serial.println(F("]************ ************************ "));
Serial.flush();
fsm_context.printFreeMemory("[main::loop]");
switch (fsm_context.stateFlow) {
case 0:
// this block is commented
case 1:
fsm_context.change_state(communicationStatePtr);
fsm_context.report_signature_request();
fsm_context.session_new(); // !! [HTTPClientState::session_new] Free Memory: 55�
// fsm_context.report_config(); // !! [HTTPClientState::report_conf�
// fsm_context.report_health_check(); // !! [HTTPClientState::report_health_check]�
case 2:
default: // Reset
fsm_context.stateFlow = -1; // Reset
fsm_context.stateFlow++;
src/Context.cpp :
#include "..\include\Context.h"
#include "..\include\core_states\BaseState.h"
extern unsigned int __bss_end; // Symbol marking the end of the .bss section (static & global variables in RAM).
extern void *__brkval; // Current end of the heap. NULL (0) if no malloc() has been used yet.
FiniteStateMachine::FiniteStateMachine(BaseState *initialStatePtr) {
currentStatePtr = initialStatePtr;
void FiniteStateMachine::change_state(BaseState *newStatePtr) {
// get milliseconds + log start
currentStatePtr->exit(this);
currentStatePtr = newStatePtr;
currentStatePtr->enter(this); // complete this line
// log end + execution time
void FiniteStateMachine::report_signature_request() {
currentStatePtr->report_signature_request(this);
void FiniteStateMachine::session_new() {
currentStatePtr->session_new(this);
void FiniteStateMachine::report_config() {
currentStatePtr->report_config(this);
void FiniteStateMachine::report_health_check() {
currentStatePtr->report_health_check(this);
void FiniteStateMachine::session_stop() {
currentStatePtr->session_stop(this);
void FiniteStateMachine::take_a_nap() {
currentStatePtr->take_a_nap(this);
void FiniteStateMachine::printFreeMemory(char *currentMethodPtr) {
int free_memory;
// If the heap hasn't been used (__brkval == 0)
if ((int)__brkval == 0) {
// free space = (address of local var / stack pointer) - (end of bss section)
free_memory = ((int)&free_memory) - ((int)&__bss_end);
// Otherwise, heap is in use
// free space = (address of local var / stack pointer) - (current end of heap)
free_memory = ((int)&free_memory) - ((int)__brkval);
Serial.print(currentMethodPtr);
Serial.print(" Free Memory: ");
Serial.print(free_memory);
Serial.println(" bytes");
I'd say you need to monitor free RAM in loop, watching for leaks, and track those down.
But. I don't see your code, so I can't say where, or when doing the above would be effective, or wasted time. Maybe start by dramatically lowering the amount of rubbish being printed, see if the code survives longer. May or may not be a hint as to what's going on. I.e. is the crash related to Serial dropping to it's knees and slowing down, or is it related to the number of times loop() cycles, and therefore something loop is calling is drawing down free memory on every pass.
Good luck.
Apologies for that, first read through the thread your code postings did not appear at all. I see you're already monitoring memory, so I have no further contributions.
I think you have a memory issue as 55 is almost nothing
the challenge monitoring available RAM is that you don't see allocations which have failed and the processing did not occur (the String class for example would fail silently) so you can see the situation before and after and not understand that it went wrong.
Tks for the hint but 55 is not the real amount of free memory. Note that 55 is followed by �, meaning the code stoped before finishing that print (the actual free memory is something around 5526 in most of the time). The available memory is one of the reasons I decided using Mega2560. This board should be able to handle at least 3x more code than we have in this scenario.
About the challenge of monitoring RAM, I'm not sure I understood it. If I can see the situation before and after a silent fail, I should be able to notice some decay of available memory at some point, which does not seem to occur.
call some library function where a huge allocation is done and fails safely
read available ram ➜ OK
as you can't inject your memory check at every single point, you can't know what happens internally.
for example, in case of memory shortage
readAvailableRam(); // say it's OK
String x = a + b + c + d + e + f; // say a,b, c, d, e and f are large strings
➜ you have no way of knowing if the concatenation failed because ram went low or if it succeeded. Transient Strings were created during the execution of that line to accumulate the data for the new final String and this could have failed.
I see… String “x“ could be incomplete (due to lack of memory) and the code would still run. But the second “readAvailableRam()“ would indicate a significant memory decay, which would be enough for me to guess that the problem is in the previous line.
Either way, unless my “printFreeMemory()“ method is badlly written, this memory leak scenario does not seem to occur in my code, since the free memory is always higher then 5500. Please fell free to review that method in src/Context.cpp and point out if there’s anything wrong with it.
Another detail that I consider relevant for this case is one that I mentioned in my introduction: If I simply add more lines of Serial.println() right after that incomplete one, the code does not break in the same exact point, it will run a few more prints.
Exemple:
Serial.println(F(“hello world“)); // prints out “hello w�“ and stops processing
If I add more prints, the code goes a little further before stoping:
Serial.println(F(“hello world“)); // prints out “hello world“
Serial.println(F(“hello Bob“)); // prints out “hello Bob“
Serial.println(F(“hello James“)); // prints out “hello Ja�“ and stops processing
I don’t know how but I belive this is an important hint to understand the problem.
You need to have Serial.flush() after every print, if you want to really see the last print.
That makes sense if the Serial buffer is full, because print() will not return until all the text is places in the print buffer. The actual last character printed may be as much as 63 characters past the last one you see.
